Re: M/T ET drag radials slipping on rims
[Re: 70Drop]
#2653085
05/07/19 05:53 PM
05/07/19 05:53 PM
Triple Threat
Renton Washington
How fast is the car and how much air pressure are you running?
[Re: 70Drop]
#2653088
05/07/19 05:59 PM
05/07/19 05:59 PM
Posts: 52,972 Romeo MI
MR_P_BODY
If you cant stop them from moving then put the screws in.. I have my DR glued on and they havent moved.. whats your tire pressure at.. you might want to up that some.. you know they arent moving now
[Re: 70Drop]
#2653298
05/08/19 09:12 AM
05/08/19 09:12 AM
Posts: 4,690 On the parachute mount
n20mstr
I put a set of Mickey Thompson ET Drag radials (9x30) on my Duster last season. They tended to move about an inch on each run. That didn't stop even after about 10 runs. One of the tires started leaking air at the bead after a run, so I dismounted the tires. The beads weren't damaged. I read that some people are glueing the beads to the rims with Permatex High Tack. So I did that when I put the tires back on. The tires are still spinning about an inch on the rims after 7 runs with the High Tack. I feel like I want to put bead screws in, but everyone (including M/T) says you can't do that on radials. So what's a poor racer supposed to do? Bead locks are expensive. Why is it that I can't use bead screws? Everybody says so, but nobody ever says why WHAT SIZE TIRE? WHAT WIDTH RIM? WHAT AIR PRESSURE?
....BAD A$$ STREET CAR.....
[Re: Clanton]
#2653317
05/08/19 09:55 AM
05/08/19 09:55 AM
Posts: 20,195 PA.
pittsburghracer
"Little"John
"Little"John
PA.
There have been so many posts on this subject but guys insist on taking shortcuts. It’s a step by step process and the best results take 2-3 days. There is no way in heck you should have issues with a 9 inch tire if you do the proper steps.
[Re: 70Drop]
#2653360
05/08/19 11:26 AM
05/08/19 11:26 AM
BradH
10.60, 1.5 60-ft., 3300 lbs. The tires like 15 lbs of pressure. More than that and they spin I suspect it's the low air pressure you use. Most radial users I know run 18-22 psi and the higher pressure seems to reduce the tire rotating on the wheel. Maybe your chassis settings aren't optimized for a radial, which requires you to run lower pressure as a Band-Aid for the chassis.
[Re: BradH]
#2653492
05/08/19 07:59 PM
05/08/19 07:59 PM
Posts: 223 California
70Drop
California
10.60, 1.5 60-ft., 3300 lbs. The tires like 15 lbs of pressure. More than that and they spin I suspect it's the low air pressure you use. Most radial users I know run 18-22 psi and the higher pressure seems to reduce the tire rotating on the wheel. Maybe your chassis settings aren't optimized for a radial, which requires you to run lower pressure as a Band-Aid for the chassis. That's exactly what I'm thinking. I've ordered mono leafs and shocks from Calvert. Hopefully that will help. Mazzolini thinks so. The glue cured on the rim/tire for over a month before I raced. I put plenty of High Tack on both the rim and the bead and waited until it tacked before joining them. I don't think I did anything wrong.
[Re: dvw]
#2653621
05/09/19 09:43 AM
05/09/19 09:43 AM
Posts: 12,589 Great Neck,LI,new york
hemi-itis
I also run the MT 10.5W on a 12 inch rim.They moved some then stopped
