Re: 09 Ram HVAC noise
[Re: TC@HP2]
#2652998
05/07/19 02:14 PM
05/07/19 02:14 PM
Posts: 15,840 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Yep, he has steered you right. I've replaced several in a few brands. Can be a PITA depending on which one. You should have one that opens and closes the fresh air versus recirculate, one for directing where air is coming out (dash vents, defrost, etc.), one for temperature adjusting (cooler or warmer), and an additional if you have dual zone climate control. I did one in a friends Chebby Impale-ya that wasn't fun. I also did all of them in my 2010 Charger. I only needed one but decided to do them all at once since I was doing the one anyway. Skinny arms definitely help on a couple.
Youtube is definitely your friend on this repair. Good luck. Hope it's one of the easier to get to ones.
Facts are stubborn things.
