Guys, teach me about 340 blocks
#2651292
05/02/19 04:55 PM
05/02/19 04:55 PM
Posts: 192 Gravataí, RS, Brazil
360tripleblack77
Hello everybody. I'm buying a 340 block in Brazil but to be honest I don't know to much about this blocks. What kind of details I need to pay attention?
I'm planning to build a Pump Gas N/A engine, 12.0CR, solid flat tapped cam, Victor Heads, Tunnel Ram, Steel main caps... Can I drill to use 4 bolt main caps or this block like 318 no has enough material to add more 2 splayed bolts?
How is safe to bore for a N/A Street engine?
Here is a picture of the cast number.
'77 Brazilian Dodge Charger R/T - Street Car Footbrake, Pump Gas, SB Mopar 360" N/A 3300lbs, Leaf Spring + Assassin Bars Best 1/8 mile ET 1.50 60' / 4.31 330' / 6.73@102.54mph
Re: Guys, teach me about 340 blocks
[Re: 360tripleblack77]
#2651325
05/02/19 07:00 PM
05/02/19 07:00 PM
Posts: 6,840 The Swamp
Sixpak
The Swamp
12.0 CR is pump gas? Lots of alcohol in the gas down there? Me personally, I'd be building a 360 - probably not as rare or $$, cheaper, bigger bore, lot's of stroker kits available, won't have to build it as radical as the 340. But..most should go .060 but get it sonic checked. 12.0 will need head studs and really good gaskets - 4 bolts per cylinder can lead to sealing issues. Years ago guys o-ringed those blocks, nowadays Cometic might make a head gasket to handle it. May need oiling mods too, if you are looking to turn some RPM. The MP/DC Engine manuals are your friend.
[Re: Sixpak]
#2651326
05/02/19 07:21 PM
05/02/19 07:21 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I have a 340 block that has 4 bolt mains but understand that the outer main bolt are 3/8" and they go straight down.. been a great block for years now.. I bought it from a dirt roundy round racer.. all my blocks are 340 based.. even my 2 bolt blocks I turn to 8000+ rpms.. sonic check ALL blocks
#2651328
05/02/19 07:25 PM
05/02/19 07:25 PM
Posts: 43,214 Bend,OR USA
Cab_Burge
Is your pump fuel straight Ethanol or Methanol now? As far as main caps I wouldn't, and don't', use steel caps on any cast iron block, ductile iron or maybe aluminum but not steel As far as bore size I would bore it just big enough to get the bores straight now and leave some meat for later development I have built several 340 NHRA legal stocker 340 motors that made 430 HP at 5900 RPM with stock 1971 heads, intake, carb and NHRA legal hydraulic camshafts and lifters That was a long time ago, early 1990s, much better parts available now I built one pump gas 340 4.0 inch long stroker motor with a set of race mildly ported race W2 heads that made 514 HP with one 850 CFM carb. on a cast single plane W2 intake using CA 91 octane pump swill Stroke that rascal and put some good heads on it and let it rock
#2651347
05/02/19 07:58 PM
05/02/19 07:58 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
Looks like you are going to make some power. I would pass on a stock block and pay the money for a R3 or a Ritter now, but thats me.
"Just a Bracket car dressed up like a streetcar"
[Re: Just-a-dart]
#2651381
05/02/19 09:51 PM
05/02/19 09:51 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
Looks like you are going to make some power. I would pass on a stock block and pay the money for a R3 or a Ritter now, but thats me. Great advice. If you want to make serious steam , you will never regret good parts in the basement.
[Re: stickman60]
#2651488
05/03/19 09:37 AM
05/03/19 09:37 AM
360tripleblack77
Thanks for all advice Guys. R3 or Ritter is not an option for me unfortunately. Price + shipping + taxes to ship to Brazil is unbelievable expensive. Best pump gas in Brazil has 96 oct and 30% of ethanol. Currently I`m running with 12.0CR on this Pump Gas, Cometic head gasket and ARP bolts. No Issues so far. This engine has a 318 block, 3.58 Scat Series 9000 and overbored to 4.000". After all machine works I did a sonic check at the cylinders bore and the thin wall measure that I found was 0.148".
I'm looking forward to use Victor Heads but this heads has 2.15 intake valves and I believe that 4.000" bore is not enough for a good valve shroud. This is the main reason that I'm thinking change for a 340 block, maybe use 4.080" or 4.100"
[Re: fullmetaljacket]
#2651562
05/03/19 12:57 PM
05/03/19 12:57 PM
Posts: 4,457 Washington
madscientist
Washington
If I'm correct, isn't that block by virtue of the casting numbers, a 6ix pack 340?
I'd also agree that a 360 is the cheaper more viable way to go and make gobs of torque without the strain. That's not a T/A block.
#2651565
05/03/19 01:15 PM
05/03/19 01:15 PM
Posts: 29,654 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
If I'm correct, isn't that block by virtue of the casting numbers, a 6ix pack 340? Nope. T/A blocks have their own casting number & the letters TA actually cast in as well.
[Re: Alaskan_TA]
#2651581
05/03/19 01:49 PM
05/03/19 01:49 PM
MR_P_BODY
One of my blocks is a TA block.. its the for runner to the X block.. thicker main webbing EDIT that 6 at the end of the number is just the casting box number.. that just another check to see if that casting box is having any issues
[Re: MR_P_BODY]
#2651633
05/03/19 04:33 PM
05/03/19 04:33 PM
Posts: 11,600 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Save the big bores for the X, R, & Ritter blocks. OE 340 blocks are thin. .030 is considered safe. Any bigger should be checked. Personally, I wouldn't go any larger than needed, unless there was a real reason. They aren't making anymore and I don't want to use it up with one overbore.
2 bolt mains and stock caps aren't the weak point. 550 to 600 is about the safe limit. Early 360s can go to 340 size bores.
[Re: CMcAllister]
#2651671
05/03/19 06:33 PM
05/03/19 06:33 PM
Posts: 4,986 new jersey usa
11secdart
new jersey usa
I agree with everybody, I ran 340s for years hard to find a good block that sonics well, switched to a 360 ( Magnum ) block awhile back I like it better more torque and top end. Now running an R3 block with a 4 inch stroke, Indy 360-1 heads
#2651677
05/03/19 06:40 PM
05/03/19 06:40 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
. In my opinion there's no need to butcher the block the head will make plenty of power
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: WHITEDART]
#2653439
05/08/19 04:07 PM
05/08/19 04:07 PM
360tripleblack77
Thank you guys! Block is over 0.30 and was sonic tested and magnafluxed. No issues and are ready to build a 4.070".
Now I need to decide what stroke I should use. 3.790 x 4.000 or 4.125?
#2653444
05/08/19 04:23 PM
05/08/19 04:23 PM
MR_P_BODY
Now I need to decide what stroke I should use. 3.790 x 4.000 or 4.125? I have a couple of 3.79 and a 4.00 strokes.. I think you would be happier with a 4.00 stroke.. plenty of them around and if you wanted a cast crank they are pretty cheap.. all my stuff is billet or forged.. the 3.79 are billet ones
[Re: MR_P_BODY]
#2653469
05/08/19 05:47 PM
05/08/19 05:47 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
If I were doing it, stroke would be determined by whether or not I was going to use stock or custom length rods and custom pistons. I would want to take advantage of the LA deck height to keep the rod ratio at least close to stock.
