Save the big bores for the X, R, & Ritter blocks. OE 340 blocks are thin. .030 is considered safe. Any bigger should be checked. Personally, I wouldn't go any larger than needed, unless there was a real reason. They aren't making anymore and I don't want to use it up with one overbore.
2 bolt mains and stock caps aren't the weak point. 550 to 600 is about the safe limit. Early 360s can go to 340 size bores.
If the results don't match the theory, change the theory.
