8 inch Torque Converters #2651203
05/02/19 12:36 PM
05/02/19 12:36 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Why do all these Converter Companies not want to sell you a 8 inch?
Everyone wants to sell you either a 9 or 9.5.
Need a new converter and everyone try's to talk me out of one.
Re: 8 inch Torque Converters [Re: Sammy] #2651207
05/02/19 12:43 PM
05/02/19 12:43 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Whats the use going to be for.. car and weight.. is it a street car
wave
Re: 8 inch Torque Converters [Re: Sammy] #2651208
05/02/19 12:47 PM
05/02/19 12:47 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Transmission Specialties has never tried taking me out of a 8 inch convertor. My last 3 have been spragless and I’ve been very happy with them. Ever without dyno numbers on my last convertor I told them I wanted 5800 stall and it ended up being 5760. Can’t beat that.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 8 inch Torque Converters [Re: Sammy] #2651223
05/02/19 01:23 PM
05/02/19 01:23 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
What one needs for a torque converter is def one of those “it depends” things.
Re: 8 inch Torque Converters [Re: MR_P_BODY] #2651226
05/02/19 01:28 PM
05/02/19 01:28 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
wave
It is application specific. Stall speed desired, power, stroke, gear, weight, intended use. With everything being big inch, big power, boosted, etc, these days, not many situations are right for that small converter.
Re: 8 inch Torque Converters [Re: Sammy] #2651331
05/02/19 07:36 PM
05/02/19 07:36 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
I have been told good 8" cores are hard to find, and most new 8" converters are usings parts from ATI.
9.5 stuff is cheap for them to buy so easier to sell cheaper/or make more money.
I am buying another 8" right now
"Just a Bracket car dressed up like a streetcar"
Re: 8 inch Torque Converters [Re: Sammy] #2651334
05/02/19 07:40 PM
05/02/19 07:40 PM
Cab_Burge Online work
Cab_Burge  Online Work
Originally most race converter company used the Opel 8 inch cores and built them for the tranny, engine and so on.
I've been told the 8 inch cores are no longer out there and not many company have any in stock to build them now confused
I've ran into the same thing in the last three years several times whiney shruggy
There is a HP limit on how well any small converter will work, the bigger the core the more power it will take before failing is what I'm being told once you get over 900 HP shruggy
For real high RPM stall, above 8500 RPM, A1 says their 7 inch is the hot set up work shruggy
Re: 8 inch Torque Converters [Re: Sammy] #2651372
05/02/19 09:32 PM
05/02/19 09:32 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
All 3 of mine are 8”.... that’s what Lenny spec’ed for my small block
Re: 8 inch Torque Converters [Re: J_BODY] #2651393
05/02/19 10:39 PM
05/02/19 10:39 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I've got 2 8's that I got from Stock Eliminator guys. One is a PTC, the other is a TCI. Pretty sure PTC will build you one. I know Edge will, and they are using billet covers now.
Re: 8 inch Torque Converters [Re: slantzilla] #2651422
05/02/19 11:53 PM
05/02/19 11:53 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
I have an 8" in a 727 in a street car. It works but it's pretty stupid. Fun though! I'm willing to sell it. Kevin at Hughes went through it. I originally got it from Marv at A-1.
Re: 8 inch Torque Converters [Re: Dave Hall] #2651438
05/03/19 02:25 AM
05/03/19 02:25 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
As has been mentioned, the 9-9.5" cores are plentiful and that's why they'll push you toward them.
Alan Jones
Re: 8 inch Torque Converters [Re: LA360] #2651463
05/03/19 07:55 AM
05/03/19 07:55 AM
Mopar
Jason B Offline
Jason B  Offline
Mopar
Well I just so happen to have 3 ATI 8” for sale LOL pick your poison.
2- Glide 8” convertors with Turbo inputs one is 67-6800 the other 7000.
1- 904 8” Transbrake convertor 7100-7200 stall
All of them are basically brand new with less than 15- 1/8 mile passes.
Asking for 800.00 plus shipping each.
Jason Buckner 936-577-1648 call or text
1968 Cuda 440" Edelbrock Victor Head Small Block.
[img]https://board.moparts.org/ubbthreads/upload4/23859.png[/img]
Re: 8 inch Torque Converters [Re: Jason B] #2651486
05/03/19 09:37 AM
05/03/19 09:37 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I have an 8 inch and I blew right throught it,,,,,is it junk now???
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: 8 inch Torque Converters [Re: hemi-itis] #2651526
05/03/19 11:15 AM
05/03/19 11:15 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I run an 8" on the street, it flashes 6400 behind my 416 and it drives well on the street. It is a turbo action that is rated at 4800.
68 Barracuda Formula S 340
Re: 8 inch Torque Converters [Re: Bad340fish] #2651534
05/03/19 11:27 AM
05/03/19 11:27 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
All depends on torque input and desired stall speed. With my combo the 9 1/2 Ultimate will flash to 6100. That's all my combo needs. If you have less input torque or need more stall then the 8" or even smaller would be appropriate.
Doug
Re: 8 inch Torque Converters [Re: hemi-itis] #2651647
05/03/19 05:26 PM
05/03/19 05:26 PM
Mopar
Jason B Offline
Jason B  Offline
Mopar
Depends on who built it and if they will stand behind it. They should be able to fix it and upgrade where needed. Only question will be is if it’s cost effective as opposed to buying new that’s already beefed up.
Jason
Re: 8 inch Torque Converters [Re: hemi-itis] #2653639
05/09/19 10:29 AM
05/09/19 10:29 AM
hemi-itis Offline
hemi-itis  Offline
Can anyone tell me the answer to this one?? I took out an 8 inch and tried a used converter.That is when realized I was blowing through the 8".Is that converter now damaged???
Re: 8 inch Torque Converters [Re: hemi-itis] #2653640
05/09/19 10:32 AM
05/09/19 10:32 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Well if it worked at one time and now does not, it may need repair. If it never worked it may just be too loose and could be tightened up. I think only a good torque converter manufacture could tell you for sure.
Re: 8 inch Torque Converters [Re: 340Cuda] #2653667
05/09/19 11:29 AM
05/09/19 11:29 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I have a 8" conv that I blew through and I.m still using it.. let it cool
down and it should be fine.. I went to 9600 rpm on mine and it normally
stalls at 5600 rpm.. I dont use a rpm chip for the stall which is how I
leave the line all the time
wave
Re: 8 inch Torque Converters [Re: hemi-itis] #2653673
05/09/19 11:40 AM
05/09/19 11:40 AM
If it drives okay at light throttle and isn't making noise or metal it is probably okay work twocents
