Fuel gauge that works with factory sender?
#2651396
05/02/19 10:47 PM
05/02/19 10:47 PM
Posts: 2,509 God's Country Maryland
GODSCOUNTRY340
Looking for an aftermarket fuel level gauge that works with the factory sending unit in the tank. Anyone have a recommendation? Just looking for a gauge compatible with the sender and float that's already in the gas tank for an early '70's car.
Re: Fuel gauge that works with factory sender?
[Re: GODSCOUNTRY340]
#2651414
05/02/19 11:35 PM
05/02/19 11:35 PM
RapidRobert
I dont have an ans but you might ohm the sender at empty/full to get some numbers to work with. I'm assuming useing an OE gauge ain't in the cards.
[Re: RapidRobert]
#2651419
05/02/19 11:38 PM
05/02/19 11:38 PM
GODSCOUNTRY340
I'm working on a '54 Dodge Power Wagon with 6 volt positive ground that I'm changing over to 12 volt negative ground so the original gauge is out. I've installed a '70's gas tank so need something that will work with it.
#2651430
05/03/19 12:16 AM
05/03/19 12:16 AM
RapidRobert
just thinking out loud,I'm assuming a voltage reducer 12 to 6 just for that gauge that would maintain an accurate needle sweep ain't possible.
[Re: RapidRobert]
#2651564
05/03/19 01:11 PM
05/03/19 01:11 PM
GODSCOUNTRY340
Thanks everyone. I found one that's compatible with Mopar & Ford senders, Equus gauge.
