Re: 8 inch Torque Converters
[Re: Sammy]
#2651208
05/02/19 12:47 PM
05/02/19 12:47 PM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Transmission Specialties has never tried taking me out of a 8 inch convertor. My last 3 have been spragless and I’ve been very happy with them. Ever without dyno numbers on my last convertor I told them I wanted 5800 stall and it ended up being 5760. Can’t beat that.
[Re: Sammy]
#2651223
05/02/19 01:23 PM
05/02/19 01:23 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
What one needs for a torque converter is def one of those “it depends” things.
[Re: MR_P_BODY]
#2651226
05/02/19 01:28 PM
05/02/19 01:28 PM
Posts: 11,611 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Whats the use going to be for.. car and weight.. is it a street car It is application specific. Stall speed desired, power, stroke, gear, weight, intended use. With everything being big inch, big power, boosted, etc, these days, not many situations are right for that small converter.
[Re: Sammy]
#2651331
05/02/19 07:36 PM
05/02/19 07:36 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
I have been told good 8" cores are hard to find, and most new 8" converters are usings parts from ATI. 9.5 stuff is cheap for them to buy so easier to sell cheaper/or make more money.
I am buying another 8" right now
"Just a Bracket car dressed up like a streetcar"
[Re: J_BODY]
#2651393
05/02/19 10:39 PM
05/02/19 10:39 PM
Posts: 20,185 Park Forest, IL
slantzilla
Park Forest, IL
I've got 2 8's that I got from Stock Eliminator guys. One is a PTC, the other is a TCI. Pretty sure PTC will build you one. I know Edge will, and they are using billet covers now.
[Re: Jason B]
#2651486
05/03/19 09:37 AM
05/03/19 09:37 AM
Posts: 12,588 Great Neck,LI,new york
hemi-itis
I have an 8 inch and I blew right throught it,,,,,is it junk now???
[Re: hemi-itis]
#2651526
05/03/19 11:15 AM
05/03/19 11:15 AM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
I run an 8" on the street, it flashes 6400 behind my 416 and it drives well on the street. It is a turbo action that is rated at 4800.
68 Barracuda Formula S 340
[Re: hemi-itis]
#2653639
05/09/19 10:29 AM
05/09/19 10:29 AM
hemi-itis
I have an 8 inch and I blew right throught it,,,,,is it junk now??? Can anyone tell me the answer to this one?? I took out an 8 inch and tried a used converter.That is when realized I was blowing through the 8".Is that converter now damaged???
[Re: hemi-itis]
#2653640
05/09/19 10:32 AM
05/09/19 10:32 AM
Posts: 3,519 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
I have an 8 inch and I blew right throught it,,,,,is it junk now??? Can anyone tell me the answer to this one?? I took out an 8 inch and tried a used converter.That is when realized I was blowing through the 8".Is that converter now damaged??? Well if it worked at one time and now does not, it may need repair. If it never worked it may just be too loose and could be tightened up. I think only a good torque converter manufacture could tell you for sure.
[Re: 340Cuda]
#2653667
05/09/19 11:29 AM
05/09/19 11:29 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I have a 8" conv that I blew through and I.m still using it.. let it cool down and it should be fine.. I went to 9600 rpm on mine and it normally stalls at 5600 rpm.. I dont use a rpm chip for the stall which is how I leave the line all the time
[Re: hemi-itis]
#2653673
05/09/19 11:40 AM
05/09/19 11:40 AM
Posts: 43,223 Bend,OR USA
Cab_Burge
I have an 8 inch and I blew right throught it,,,,,is it junk now??? Can anyone tell me the answer to this one?? I took out an 8 inch and tried a used converter.That is when realized I was blowing through the 8".Is that converter now damaged??? If it drives okay at light throttle and isn't making noise or metal it is probably okay
