Small Block Oil Pump Gasket
#2651050
05/01/19 09:08 PM
05/01/19 09:08 PM
Posts: 2,117 Byron, NY
W.I.N. Racing
Byron, NY
Small Block Oil Pump Gasket who uses them. Been a while since I've done a SB but dont remember using one.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Small Block Oil Pump Gasket
[Re: b1dartsport]
#2651205
05/02/19 12:43 PM
05/02/19 12:43 PM
Posts: 20,195 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Throw those thin pieces of crap that they give you in the trash and bolt it on. Anytime I’ve taken one apart that had a gasket on it it’s always squeezed out and ripped anyway leading to more issues.
[Re: pittsburghracer]
#2651234
05/02/19 01:59 PM
05/02/19 01:59 PM
Posts: 429 Washington
skrews
Washington
Throw those thin pieces of crap that they give you in the trash and bolt it on. Anytime I’ve taken one apart that had a gasket on it it’s always squeezed out and ripped anyway leading to more issues. This X 1000
[Re: skrews]
#2651252
05/02/19 02:55 PM
05/02/19 02:55 PM
Posts: 11,652 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Use some fine paper on a flat surface (glass, etc.) and rub up the mating surfaces of the cap and pump while you're massaging and port matching to correct any burrs/rough machining.
[Re: W.I.N. Racing]
#2651266
05/02/19 03:35 PM
05/02/19 03:35 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
The engine assembly was designed NOT to use any kind of fiber/paper type gasket. Although many gasket companies, as well as the typical Melling oil pump package, comes with a thin gasket, you are best to simply inspect the mating surfaces (oil pump and block/cap) so to assure flatness and no pitting or metal flash, then only use an anaerobic sealer (cures between metal-to-metal in the absence of air... DO NOT USE RTV silicone which requires air), then tighten to OE specs.
The very last thing you'd want is for some foreign material -- gasket material and/or RTV silicone -- to find its way into the oil pump or passage ways to then restrict the flow of oil.
Remember: RTV silicones are the most widely mis-used and improperly applied chemicals in the engine building industry. RTV should only be used at critical open-gap intersecting corners, such as the four corners of an Intake mfld or oil pan gasket assembly. Avoid spreading RTV all across a pre-made gasket, and never onto a rubber gasket.
I'm a former gasket engineer from a major company, wrote the instructions within their kits, taught hundreds of seminars, and was the lead person on their tech-line.
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: Mopar Mitch]
#2651365
05/02/19 09:21 PM
05/02/19 09:21 PM
W.I.N. Racing
Byron, NY
Thanks all...As I said I don't ever remember using one but its been 20 plus years since I've done a SB plus my memory is 20 plus years older as well so just needed a push.
[Re: W.I.N. Racing]
#2651527
05/03/19 11:17 AM
05/03/19 11:17 AM
RapidRobert
On a side note while you are in there, check the clearance beween the counterweight & the underside of the pump body. & have the intergear in before you torque the 2 pump bolts (gives a dead on hex interface fit).
[Re: RapidRobert]
#2651574
05/03/19 01:32 PM
05/03/19 01:32 PM
Posts: 1,927 Seaford, Va
Kindafast
Seaford, Va
You guys have a lot of knowledge , I wish I would have asked that question before I put my junk back together. I have always used the gasket supplied with the pump. Never had a problem but this info is good to know.
6.50 @105.26
[Re: Kindafast]
#2651590
05/03/19 02:09 PM
05/03/19 02:09 PM
Posts: 4,457 Washington
madscientist
Washington
You guys have a lot of knowledge , I wish I would have asked that question before I put my junk back together. I have always used the gasket supplied with the pump. Never had a problem but this info is good to know. I've always used a gasket. I've taken apart more than my fair share of engines that had never been touched and almost every one of them had a gasket. Never had a blowout. There is no way two machined surfaces can seal without a gasket and seal correctly. You didn't do anything wrong.
[Re: madscientist]
#2651937
05/04/19 04:13 PM
05/04/19 04:13 PM
Posts: 25,925 Rio Linda, CA
John_Kunkel
Rio Linda, CA
[quote=Kindafast] I've taken apart more than my fair share of engines that had never been touched and almost every one of them had a gasket. Never had a blowout. And yet I find no part number for a gasket and no mention of one in service manuals. Last mention of a gasket between the pump and cap was in the fifties and it was a lathe cut O ring.
[Re: John_Kunkel]
#2651992
05/04/19 07:32 PM
05/04/19 07:32 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Never saw one in a factory engine. Plenty of stuff is put together with sealants only.
[Re: CMcAllister]
#2652000
05/04/19 08:01 PM
05/04/19 08:01 PM
Posts: 855 ontario canada kingston
aspenrt360
I also have never seen one in a factory engine and i have never used one or had any issues without one.
2013 Chrysler 300 touring 1974 Dodge Charger SE. 360-727-8.75-3.23 sure grip 1972 Dodge Dart Swinger 1995 Dodge Ram 1500 4x4
[Re: aspenrt360]
#2652018
05/04/19 09:12 PM
05/04/19 09:12 PM
Posts: 20,195 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I’ve never taken one apart that had any type of gasket sealer on it either. Take the bolts out and it lifts right off.
