Small Block Oil Pump Gasket #2651050
05/01/19 09:08 PM
05/01/19 09:08 PM
Byron, NY
W.I.N. Racing Offline OP
Byron, NY
Small Block Oil Pump Gasket who uses them. Been a while since I've done a SB but dont remember using one.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Small Block Oil Pump Gasket [Re: W.I.N. Racing] #2651051
05/01/19 09:23 PM
05/01/19 09:23 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Nope.. I dont
wave
Re: Small Block Oil Pump Gasket [Re: W.I.N. Racing] #2651052
05/01/19 09:24 PM
05/01/19 09:24 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Never used a gasket.. Just a thin smear of silicone.
Re: Small Block Oil Pump Gasket [Re: W.I.N. Racing] #2651086
05/01/19 11:01 PM
05/01/19 11:01 PM
I don't think I've ever assembled a SB without one work shruggy
Most of the ones that came in the box with the new pumps where real thin gasket material, thin like writing paper shruggy
Re: Small Block Oil Pump Gasket [Re: W.I.N. Racing] #2651089
05/01/19 11:19 PM
05/01/19 11:19 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
Ive always just used a very thin film of red anaerobic sealer
Re: Small Block Oil Pump Gasket [Re: gtx6970] #2651200
05/02/19 12:27 PM
05/02/19 12:27 PM
western pennsylvania
b1dartsport Offline
b1dartsport  Offline
Built at least 10 engines without it. When tearing down virgin engines that were original 60s to 70s there was no gasket from the factory.
Re: Small Block Oil Pump Gasket [Re: b1dartsport] #2651205
05/02/19 12:43 PM
05/02/19 12:43 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Throw those thin pieces of crap that they give you in the trash and bolt it on. Anytime I’ve taken one apart that had a gasket on it it’s always squeezed out and ripped anyway leading to more issues.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Small Block Oil Pump Gasket [Re: pittsburghracer] #2651234
05/02/19 01:59 PM
05/02/19 01:59 PM
Washington
skrews Offline
skrews  Offline
Washington
This X 1000
Re: Small Block Oil Pump Gasket [Re: skrews] #2651252
05/02/19 02:55 PM
05/02/19 02:55 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Use some fine paper on a flat surface (glass, etc.) and rub up the mating surfaces of the cap and pump while you're massaging and port matching to correct any burrs/rough machining.
Re: Small Block Oil Pump Gasket [Re: CMcAllister] #2651254
05/02/19 03:05 PM
05/02/19 03:05 PM
MR_P_BODY Offline
MR_P_BODY  Offline
This is all I do
wave
Re: Small Block Oil Pump Gasket [Re: W.I.N. Racing] #2651266
05/02/19 03:35 PM
05/02/19 03:35 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
The engine assembly was designed NOT to use any kind of fiber/paper type gasket. Although many gasket companies, as well as the typical Melling oil pump package, comes with a thin gasket, you are best to simply inspect the mating surfaces (oil pump and block/cap) so to assure flatness and no pitting or metal flash, then only use an anaerobic sealer (cures between metal-to-metal in the absence of air... DO NOT USE RTV silicone which requires air), then tighten to OE specs.
The very last thing you'd want is for some foreign material -- gasket material and/or RTV silicone -- to find its way into the oil pump or passage ways to then restrict the flow of oil.
Remember: RTV silicones are the most widely mis-used and improperly applied chemicals in the engine building industry. RTV should only be used at critical open-gap intersecting corners, such as the four corners of an Intake mfld or oil pan gasket assembly. Avoid spreading RTV all across a pre-made gasket, and never onto a rubber gasket.
I'm a former gasket engineer from a major company, wrote the instructions within their kits, taught hundreds of seminars, and was the lead person on their tech-line.
Re: Small Block Oil Pump Gasket [Re: Mopar Mitch] #2651365
05/02/19 09:21 PM
05/02/19 09:21 PM
Byron, NY
Byron, NY
Thanks all...As I said I don't ever remember using one but its been 20 plus years since I've done a SB plus my memory is 20 plus years older as well so just needed a push.
'60 Willys CJ5
Re: Small Block Oil Pump Gasket [Re: W.I.N. Racing] #2651527
05/03/19 11:17 AM
05/03/19 11:17 AM
On a side note while you are in there, check the clearance beween the counterweight & the underside of the pump body. & have the intergear in before you torque the 2 pump bolts (gives a dead on hex interface fit).
Re: Small Block Oil Pump Gasket [Re: RapidRobert] #2651574
05/03/19 01:32 PM
05/03/19 01:32 PM
Seaford, Va
Kindafast Offline
Kindafast  Offline
Seaford, Va
You guys have a lot of knowledge , I wish I would have asked that question before I put my junk back together. I have always used the gasket supplied with the pump. Never had a problem but this info is good to know.
6.50 @105.26
Re: Small Block Oil Pump Gasket [Re: Kindafast] #2651590
05/03/19 02:09 PM
05/03/19 02:09 PM
Washington
madscientist Offline
Washington
I've always used a gasket. I've taken apart more than my fair share of engines that had never been touched and almost every one of them had a gasket. Never had a blowout.
There is no way two machined surfaces can seal without a gasket and seal correctly.
You didn't do anything wrong.
Re: Small Block Oil Pump Gasket [Re: W.I.N. Racing] #2651699
05/03/19 07:35 PM
05/03/19 07:35 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
No gskt. When checking the counterweight flycut clearance, check the pump body as well. I had a Melling that was paper thin, and blew out.
Re: Small Block Oil Pump Gasket [Re: madscientist] #2651937
05/04/19 04:13 PM
05/04/19 04:13 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Originally Posted by madscientist
[quote=Kindafast] I've taken apart more than my fair share of engines that had never been touched and almost every one of them had a gasket. Never had a blowout.
And yet I find no part number for a gasket and no mention of one in service manuals. Last mention of a gasket between the pump and cap was in the fifties and it was a lathe cut O ring.
Re: Small Block Oil Pump Gasket [Re: John_Kunkel] #2651992
05/04/19 07:32 PM
05/04/19 07:32 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Never saw one in a factory engine. Plenty of stuff is put together with sealants only.
Re: Small Block Oil Pump Gasket [Re: CMcAllister] #2652000
05/04/19 08:01 PM
05/04/19 08:01 PM
ontario canada kingston
aspenrt360 Offline
aspenrt360  Offline
I also have never seen one in a factory engine and i have never used one or had any issues without one.
2013 Chrysler 300 touring 1974 Dodge Charger SE. 360-727-8.75-3.23 sure grip 1972 Dodge Dart Swinger 1995 Dodge Ram 1500 4x4
Re: Small Block Oil Pump Gasket [Re: aspenrt360] #2652018
05/04/19 09:12 PM
05/04/19 09:12 PM
PA.
"Little"John
"Little"John
PA.
I’ve never taken one apart that had any type of gasket sealer on it either. Take the bolts out and it lifts right off.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
