Koenigsegg FreeValve-interesting video #2650695
04/30/19 10:13 PM
04/30/19 10:13 PM
Tulsa OK
Bad340fish Offline OP
Tulsa OK
Cool video I ran across on youtube. I know Koenigsegg uses this on their multi million dollar super cars but it looks like they are working to integrate it into regular cars. I found this video to be very interesting, especially the part where they say the valves control the throttle, no throttle blade! When do you think they will come out with a conversion for my W2 heads? lol
https://youtu.be/S3cFfM3r510
68 Barracuda Formula S 340
Re: Koenigsegg FreeValve-interesting video [Re: Bad340fish] #2650844
05/01/19 12:18 PM
05/01/19 12:18 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Pneumatic valvetrain is not new, also not allowed per the NHRA rule book as I recall for some reason shruggy
Re: Koenigsegg FreeValve-interesting video [Re: Bad340fish] #2650941
05/01/19 03:42 PM
05/01/19 03:42 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
Electric and pneumatic are fairly common on research engines. Fiat uses Multiair, which uses a long base cam profile and can hydraulically control open/closing/lift.
From an efficiency standpoint, the focus is mainly de-throttling to reduce pumping losses at part load, these concepts also help in transient response, as even modern VVT is quite slow.
There are some challenges though, load control is very difficult, because if the valve events are varying by a small amount (1-2 degrees every cycle) the engine will be perceived as rough. Even with Multiair, Fiat was not able to open the throttle completely at low loads.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: Koenigsegg FreeValve-interesting video [Re: Bad340fish] #2651001
05/01/19 06:17 PM
05/01/19 06:17 PM
He says the valve train is controlled by pneumatic but I didn't see any hoses or fitting on those valve actuators work
I did see spade tip electrical connectors on the things that look like EFI injectors around the valves confused work shruggy
As already mentioned pneumatic valve control has been used in Formula 1 racing for a long, long time. I remember hearing that those motors where running in the 20,000 + RPM years ago, maybe back in the mid to late 1980s confused
Re: Koenigsegg FreeValve-interesting video [Re: Cab_Burge] #2651069
05/01/19 10:02 PM
05/01/19 10:02 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The F1 valvetrain uses nitrogen because there is no moisture to be concerned with.
Re: Koenigsegg FreeValve-interesting video [Re: Stanton] #2651070
05/01/19 10:08 PM
05/01/19 10:08 PM
Tulsa OK
Tulsa OK
I know the pneumatic valve train has been around awhile. It was just interesting to hear all the things that could be done with it.
Re: Koenigsegg FreeValve-interesting video [Re: Bad340fish] #2651098
05/02/19 12:38 AM
05/02/19 12:38 AM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
That is a ridiculously complex way to achieve 200 some horsepower in a passenger car engine.
A small block V8 would be way simpler, more reliable, and run circles around it for a fraction of the cost.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Koenigsegg FreeValve-interesting video [Re: Hemi_Joel] #2651157
05/02/19 10:06 AM
05/02/19 10:06 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Quote
Redneck thinking !!! I guess you missed the part about the percentage increase in horsepower and torque as well as the weight savings.
Re: Koenigsegg FreeValve-interesting video [Re: Hemi_Joel] #2651163
05/02/19 10:29 AM
05/02/19 10:29 AM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
That's why it will never be in mass production. It's an exponential increase in complexity for an incremental increase in efficiency over a modern VVT+Turbo engine. A small block at 200 hp isn't going to happen either, most of those are close to twice that number. That level of development is fine for the multimillion dollar hypercars and high level racing stuff. Higher efficiencies for pass cars aren't coming for ICEs, it's going to be EV. twocents
Re: Koenigsegg FreeValve-interesting video [Re: Skeptic] #2651167
05/02/19 10:39 AM
05/02/19 10:39 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Never say never, at one time the computer controlled fuel injection, VVT and ignition were thought to be way to expensive for the common man.
Warren Johnson advocated pneumatic valve springs many years ago saying that the cost would be less than the huge valve spring bill Pro Stock teams had then and still have now.
Re: Koenigsegg FreeValve-interesting video [Re: Hemi_Joel] #2651199
05/02/19 12:23 PM
05/02/19 12:23 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Amen to that.....
Re: Koenigsegg FreeValve-interesting video [Re: B1MAXX] #2651265
05/02/19 03:30 PM
05/02/19 03:30 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
Did any of you guys watch that video till the end?!?, all the advantages to this style valves mean I bet we'll be seeing them soon.....much sooner than you all think.....makes engine shorter, smaller, and simpler and perform much better? This is a no brainer over direct injection......Which IS being used today.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Koenigsegg FreeValve-interesting video [Re: HemiRick] #2651553
05/03/19 12:32 PM
05/03/19 12:32 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
I've been accused of only having 10 sec. attention span... panic
Re: Koenigsegg FreeValve-interesting video [Re: B1MAXX] #2651557
05/03/19 12:41 PM
05/03/19 12:41 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Shorter smaller, who cares? messed up priorities. THe best looking car have room under the hood. Simpler? electronics vs mechanical? Apparently they think electronics is simple. Better performance? only compared to their other crap, not compared to a Hemi.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Koenigsegg FreeValve-interesting video [Re: Hemi_Joel] #2651623
05/03/19 03:57 PM
05/03/19 03:57 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I believe the f1 engines are using air springs not necessarily pneumatic controls, they just return the valve like a spring normally would with air trapped under the retainer with a traditional cam lobe opening it, it allows less "spring" pressure when RPM is low and increased pressure as the RPM goes up and there is no fatigue or [censored] monic oscillation like metal springs will exhibit.. To the best of my understanding this freevalve thing is an electronic solenoid that opens and closes the valve and so has infinite amounts of lift and duration possibilities in a nanosecond.
Re: Koenigsegg FreeValve-interesting video [Re: HotRodDave] #2651624
05/03/19 04:06 PM
05/03/19 04:06 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
He calls it pneumatic in the video but I see big solenoids especially around 7:40 its very clear so maybe they are using some of both.
Re: Koenigsegg FreeValve-interesting video [Re: 340Cuda] #2651751
05/03/19 10:10 PM
05/03/19 10:10 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Originally Posted by 340Cuda
Never say never, at one time the computer controlled fuel injection, VVT and ignition were thought to be way to expensive for the common man.The "cutting edge" '66 VW Squareback I drove in High School had computer controlled fuel injection , it WAS EFI, Not the older mechanical CIS and the computer wasn't hugely capable, but certainly available to the "common man" (whoever that is). I've been wrenching professionally for 35 years now and most of those Techs have been on mass produced cars for decades. It's gotten more refined, that's all.
_ Christian Koenigsegg is a genus engineer that has surrounded himself with top notch talent and builds boutique hypercars that are more like automotive erotica than a Toyota Camry or Ford F150.
_ It's going to take a LOT more that a 3 year old YouTube clip, some breathless reviews of a prototype by various automotive mags and reports of interest by a Chinese EV company and an startup Swedish company to convince me that it's anything more than an interesting engineering exercise.
_All of the major players are spending big money on EVs, not ICEs.
_ Still it's not a hill I'm willing to die on, so I'll revise my statement to Highly unlikely to see mass production, no more than 1,000 units per year- which is trivial. If it happens after I die then it doesn't count grin
Warren Johnson advocated pneumatic valve springs many years ago saying that the cost would be less than the huge valve spring bill Pro Stock teams had then and still have now. Pneumatic valve springs are another tech that no one has seen fit to put that into production engines, just a few highly developed race engines. That is only a part of what the FreeValve engine is about, it's Camless, a whole 'nether level above that. Pro Stock race engines don't qualify as mass produced, there are how many teams running PS anymore? I don't keep track, but there can't be much more than 100 PS engines currently running including backups and development.
