Re: Another “what cam” thread...
[Re: Cab_Burge]
#2650138
04/29/19 10:02 AM
04/29/19 10:02 AM
Posts: 1,745 Maryland
340_Dart
Maryland
Is this a pump gas street motor? If so you will probably have detonation problems on todays pump swill with that much compression : Yeah Cab, I'm thinking it may have problems on pump gas.... But that's the cards I've been dealt with this build. Backstory of this motor, the longblock was apparently built in the 80s (guessing from the bearing date codes) and never used, My uncle bought it 10-12 years ago and got it running in his Dart with a single 4bbl and it sat... Last year at Carlisle he bought the cross ram setup and manifolds. Went to put the cross ram on last fall and noticed a loose rocker, further investigation showed the cam had a flat lobe...So he asked me to go through it. I cleaned and checked it out, new cam bearings, crank polished, and new rod and mains are on order. I know the pistons are TRW replacement 11:1 pistons. I'm hoping once I get checking piston height and head CCs that i'll end up with less than 11:1 compression. It previously had a Crane ZIP 510 solid FT cam in it. .ZIP-510 for the B/RB .340" intake lobe lift, .3455" exhaust lobe lift, Valve lash is .028" intake, .032" exhaust at operating temperature. The duration at .050" tappet lift is 254 degrees intake, 264 degrees exhaust. Lobe separation is 112 degrees.
[Re: 340_Dart]
#2650155
04/29/19 10:36 AM
04/29/19 10:36 AM
Posts: 145 NJ
cb1289
NJ
Crane Zip 510. There's your cam right there! A great cam for that combo.
Sorry, I reread and saw the flat cam lobe after I replied.
62 Dodge Dart Wagon
65 Plymouth Satellite
[Re: 340_Dart]
#2650177
04/29/19 11:37 AM
04/29/19 11:37 AM
Posts: 4,457 Washington
madscientist
Washington
Is this a pump gas street motor? If so you will probably have detonation problems on todays pump swill with that much compression : Yeah Cab, I'm thinking it may have problems on pump gas.... But that's the cards I've been dealt with this build. Backstory of this motor, the longblock was apparently built in the 80s (guessing from the bearing date codes) and never used, My uncle bought it 10-12 years ago and got it running in his Dart with a single 4bbl and it sat... Last year at Carlisle he bought the cross ram setup and manifolds. Went to put the cross ram on last fall and noticed a loose rocker, further investigation showed the cam had a flat lobe...So he asked me to go through it. I cleaned and checked it out, new cam bearings, crank polished, and new rod and mains are on order. I know the pistons are TRW replacement 11:1 pistons. I'm hoping once I get checking piston height and head CCs that i'll end up with less than 11:1 compression. It previously had a Crane ZIP 510 solid FT cam in it. .ZIP-510 for the B/RB .340" intake lobe lift, .3455" exhaust lobe lift, Valve lash is .028" intake, .032" exhaust at operating temperature. The duration at .050" tappet lift is 254 degrees intake, 264 degrees exhaust. Lobe separation is 112 degrees. I'd call Jim at Racer Brown and spend some time on the phone with him. I run 11:1 on pump gas with iron heads and I'm not having issues. He has some lobes just for stuff like this. It's worth your time to spend some time on the phone with him so you aren't guessing and doing it twice.
[Re: Cab_Burge]
#2650326
04/29/19 07:39 PM
04/29/19 07:39 PM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Andyf liked a certain flat tappet mopar cam, he should chime in and spill the beans. Seems any car with stock manifolds could only use so much duration and overlap. You could send him a pm for his input.
[Re: Belvedere1]
#2650524
04/30/19 12:44 PM
04/30/19 12:44 PM
Posts: 43,215 Bend,OR USA
Cab_Burge
Which one, 415 or 425 HP? The 1963 cam is the same for both motors, not sure about the specs. on the 1962 413 M.W. All of them where drag race cams, not mild at all at that time There are a lot better choices on cams today for most any type build
[Re: Belvedere1]
#2650725
04/30/19 11:31 PM
04/30/19 11:31 PM
Cab_Burge
I think the stage III was for 64 425 HP and was the hottest cam of the max wedge years. Not sure of the specs but around .520 and 250 something? The 413 and most of the 1963 M.W. motors where stage 1 motors, mid year in 1963 Mopar came out with the Stage 2 425 HP motor that had the same carbs and camshaft as the 425 HP 1964 M.W. came with. All the 1964 M.W. motors where considered and called Stage 3 is what I remember from back then I think all the 1963 cams where considered 300 degree total duration with right at .509 lift, the 1964 415 HP motors had a little more duration, either 312 or 316 degrees advertised with around .510 lift at the valves and the 1964 425 HP motors had the biggest wedge made for production cars with 320 degrees advertised duration and right at .520 valve lift All the Mopar ductile iron rocker arms I've check where no where near perfect, most didn't meet the 1.5 ratio, always less
[Re: BradH]
#2650737
05/01/19 12:18 AM
05/01/19 12:18 AM
Posts: 31,046 Oregon
AndyF
MP .528, or something along those lines, based on the description above.
I also agree that 11.0 CR with open chamber iron heads will be a problem on pump gas, if the CR is really that high. Yep, that is what I'd put in there. The MP .528 will pull hard and the car will seem really fast even if it isn't. It will be fun to drive on the street and sound good. If you put a real race cam in there then it might sound mean but it won't be any fun to drive.
[Re: AndyF]
#2650796
05/01/19 10:00 AM
05/01/19 10:00 AM
Posts: 14,504 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
If I had a 528 cam sitting on the shelf, I’d probably use it in something like that.
But at the nearly $400 they go for now........ there’s a lot of options.
[Re: fast68plymouth]
#2651035
05/01/19 08:22 PM
05/01/19 08:22 PM
Posts: 889 Oh
parksr5
Oh
But at the nearly $400 they go for now........ there’s a lot of options. Dwayne, theoretically, couldn't you just essentially order a "custom" grind through your cam supplier with the 528 specs for cheaper than what the MP cam cost?
#2651046
05/01/19 08:56 PM
05/01/19 08:56 PM
Posts: 4,316 Prospect, PA
BSB67
Prospect, PA
But at the nearly $400 they go for now........ there’s a lot of options that are better Fixed
[Re: BSB67]
#2651155
05/02/19 10:00 AM
05/02/19 10:00 AM
Posts: 4,395 The Pale Blue Dot
Skeptic
The Pale Blue Dot
The engines we are talking about were engineered 60 years ago, any improvements will be incremental, not revolutionary. In the context of the OP, i.e. street cruiser, exhaust manifolds, high street CR - not dedicated race engine. Throwing a lot of dyno time and more expensive components-i.e. roller cams, beehive springs, ect- there could be improvements here and there, but in the end it's a 1950s era engine.
