Re: R3 roller lifter question [Re: 1967dartgt] #2649136
04/26/19 07:47 AM
04/26/19 07:47 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Originally Posted by 1967dartgt
I ground my factory block for roller lifters had no problem there.
Factory block isnt an issue running roller lifters. Many just drop in. Same with X block. Just drop in
59 degree R3 blocks are different in the lifter valley area than all others
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: R3 roller lifter question [Re: B3422W5] #2649142
04/26/19 07:57 AM
04/26/19 07:57 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Just for reference here is a 59* R1 with a Crane Roller lifter(old MP part#). This has been through Shady Dell's CNC Program. These lifters clear just fine but the comp 828-16 wouldn't and I had used them on a 360 block with no grinding in the past.
68 Barracuda Formula S 340
Re: R3 roller lifter question [Re: pittsburghracer] #2649146
04/26/19 08:24 AM
04/26/19 08:24 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I used the Comp 8043 on my R1 and only had to cut the extra bolt bosses off. The 8043 has the link bars moved to the inside instead of being on the bore side of the block.
Re: R3 roller lifter question [Re: pittsburghracer] #2649188
04/26/19 09:37 AM
04/26/19 09:37 AM
PA.
pittsburghracer Offline OP
"Little"John
"Little"John
PA.
WOW!!!!! 4 year old post and I'm still running a solid lifter cam. LOL. Well it hasn't been all bad as the EDM lifters have held up well and its gone 5.98 in the 1/8 and 9.42 in the 1/4 running out get up and go on the top end. Which is really fine because every track I now race at runs 1/8 mile for my class. I was hoping to pull it and install another engine so I could freshen it but my get up and go got up and left. I changed the oil and transmission fluid, cut the oil filter apart (it looked GREAT) rebuilding the carb, new seat belts, and racing it. The 2019 race season is here.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: R3 roller lifter question [Re: pittsburghracer] #2649212
04/26/19 10:19 AM
04/26/19 10:19 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
LOL! I didn't pay any attention to the date, just replied after looking through it.
Re: R3 roller lifter question [Re: justinp61] #2649223
04/26/19 10:55 AM
04/26/19 10:55 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
When my Dad and I built this engine comp was out of the 8043 and couldn't meet our timeline. My Dad reached into his small block archives and pulled out a 18 year old set of roller lifters brand new in the box and they worked great haha.
I saw the age of the post but added some info for anyone who may search in the future, I happen to have the heads off so it was easy to snap some pictures real quick.
Re: R3 roller lifter question [Re: b1dartsport] #2649423
04/26/19 09:40 PM
04/26/19 09:40 PM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
Ryan at shady dell has a CNC program for that block to make a roller lifter fit
Re: R3 roller lifter question [Re: scottb] #2649434
04/26/19 10:59 PM
04/26/19 10:59 PM
PA.
"Little"John
"Little"John
PA.
I saw that on his website but by time I drove out there twice I will have it done by hand. A lot cheaper too 😂
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: R3 roller lifter question [Re: pittsburghracer] #2649501
04/27/19 10:02 AM
04/27/19 10:02 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Just be careful, I understand there is a water jacket that sometimes makes a surprised appearance.
Re: R3 roller lifter question [Re: 340Cuda] #2649509
04/27/19 10:30 AM
04/27/19 10:30 AM
PA.
"Little"John
"Little"John
PA.
Like a said this is just my "bracket car" and running 6.0's is kind of a nice place to be. If and when I go to rebuild this engine I will see how the cam is holding up and go from there.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: R3 roller lifter question [Re: pittsburghracer] #2649526
04/27/19 11:21 AM
04/27/19 11:21 AM
The Great White North
RAMM Offline
RAMM  Offline
His "CNC" program is a joke, He runs an end mill straight down the valley knocking off the inboard head bolt bosses and shortening the lifter bosses. You still need to hand grind the valley walls for clearance.
I wound up getting an R3 block from a very good customer and I wound up doing a proper CNC profiling program that follows the contours of the block--It worked and looked really trick but it was not cheap. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: R3 roller lifter question [Re: RAMM] #2649819
04/28/19 10:53 AM
04/28/19 10:53 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I have had him to two blocks and have been very pleased with the results.
