Engine Noise - How to post a Video to Diagnose?
#2648721
04/25/19 09:19 AM
04/25/19 09:19 AM
Posts: 1,149 NW New Jersey
RSI700VIPER
NW New Jersey
My motor is making a funny rattling noise coming from the mid-lower front of the engine. It's erratic at idle and becomes more pronounced when I increase RPMs. I pulled the plug wires one at a time, disconnected belts, checked timing, plugs, etc. and everything seems in order. Compression check too. I have a 25 second video of the motor running where you can hear the noise. Is there anyway to post a video on this site so that the experts here can help diagnose?
1970 Superbird 440 Six BBL, 4-Speed, Dana, FJ5 1969 Daytona Charger 440 4-Speed, Dana, EV2 1971 340 Challenger Conv. Flemington Speedway Pace Car, FC7 1970 340 Six Pack Callenger T/A 4-speed T8 Tan 1971 340 Challenger RT Formal Roof, EV2 w/ V2 Stripe & Orange Houndstooth 1969 Talladega Torino, 428CJ 1969 Gurney Special Cyclone Spoiler II, 351 Cleveland
"Id rather have a bottle in front of me than a frontal lobotomy" Ben Franklin 1755
Re: Engine Noise - How to post a Video to Diagnose?
[Re: ScottSmith_Harms]
#2648929
04/25/19 04:25 PM
04/25/19 04:25 PM
RSI700VIPER
NW New Jersey
[Re: Greentween]
#2648943
04/25/19 05:13 PM
04/25/19 05:13 PM
Posts: 13,621 md
mopars4ever
md
Auto trans? wouldn`t hurt to check the check torque converter bolts. Use a piece of hose to try and isolate where the sound is coming from.
[Re: mopars4ever]
#2648987
04/25/19 07:13 PM
04/25/19 07:13 PM
RSI700VIPER
NW New Jersey
4-speed. I'll try posting on you-tube and link it.
[Re: RSI700VIPER]
#2648988
04/25/19 07:28 PM
04/25/19 07:28 PM
RSI700VIPER
NW New Jersey
I'm unable to post it on you-tube, or even e-mail it to myself. File must be to large. GRRRRRR
#2649018
04/25/19 08:44 PM
04/25/19 08:44 PM
RSI700VIPER
NW New Jersey
Scott, it does (509) and it's relatively new, about 2 years old. I've had a bad lifter here and there, and it produced a ticking noise under the valve cover. The noise I'm hearing with this problem sounds more like a pre-ignition rattle. Very erratic, mid-lower front of motor. I'm about ready to pull the timing cover and pan. Sucks.
[Re: topside]
#2649023
04/25/19 08:51 PM
04/25/19 08:51 PM
RSI700VIPER
NW New Jersey
What harmonic balancer is on the motor? A/C car? Pulling the belts off would eliminate the alternator & water pump. I'll assume you've already checked the fan & pulley for any wobble. Does it sound like a bad bearing, or a rhythmic ticking, or contact between a rotating item and pan or tray? Definitely from the front? Does it change with clutch pushed in? Might want to pull valve covers & poke around, though you said "middle front". No wobble with fan or pulley. Not rhythmic, more like an inconsistant rattle, like pre-ignition when you hammer down with crappy gas. 90% sure its from front. Didn't check it with clutch engaged, good idea...
#2649029
04/25/19 08:54 PM
04/25/19 08:54 PM
RSI700VIPER
NW New Jersey
Scott, pulled each plug wire one by one and noise remains. Although it got slightly louder when motor warmed up.
[Re: PDR Dude]
#2649032
04/25/19 08:57 PM
04/25/19 08:57 PM
RSI700VIPER
NW New Jersey
Not sure of history on rebuild except it got a cam about 2 years ago. Only owned the car for a few months and the noise hasn't changed, but only put about 50 miles on the car.
[Re: RSI700VIPER]
#2649045
04/25/19 09:17 PM
04/25/19 09:17 PM
Posts: 2,815 Sobieski Wi
bee1971
Sobieski Wi
When it got the cam
Was the oil slinger installed backwards on the crank ?
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
[Re: RSI700VIPER]
#2649049
04/25/19 09:22 PM
04/25/19 09:22 PM
Posts: 16,846 Between Houston & Galveston TX
SattyNoCar
Wonder if it's with the timing chain and/or oil slinger (assuming they put one on). I had a video of what my Dakota sounded like when it's chain was hitting the cover, but, photobucket was kind enough to delete it for me. ![mad mad](/ubbthreads/images/graemlins/custom/mad.gif) If your video is only 15 seconds long and won't upload, it sounds like it's formatted wrong.
John
[Re: RSI700VIPER]
#2649124
04/26/19 06:08 AM
04/26/19 06:08 AM
Posts: 1,644 Florida
GMP440
Go underneath and check the pulley to harmonic balancer bolts. You may have one or a couple bolts too long making them scrape against the timing case cover. Had this happen on a 68 Roadrunner with 383. We did a new rebuild. On start up we get this noise we could not find. With the engine off, went underneath , noticed that the pulley to harmonic balancer bolts were too long and scraping the cover. We put shorter bolts on and no more noise.
[Re: GMP440]
#2649359
04/26/19 05:11 PM
04/26/19 05:11 PM
RSI700VIPER
NW New Jersey
After a new rebuild and learning it was just a bolt... wow that stinks. I'll check the bolts tonight.
