Engine Noise - How to post a Video to Diagnose? #2648721
04/25/19 09:19 AM
04/25/19 09:19 AM
NW New Jersey
RSI700VIPER Offline OP
NW New Jersey
My motor is making a funny rattling noise coming from the mid-lower front of the engine. It's erratic at idle and becomes more pronounced when I increase RPMs. I pulled the plug wires one at a time, disconnected belts, checked timing, plugs, etc. and everything seems in order. Compression check too. I have a 25 second video of the motor running where you can hear the noise. Is there anyway to post a video on this site so that the experts here can help diagnose?
1970 Superbird 440 Six BBL, 4-Speed, Dana, FJ5
1969 Daytona Charger 440 4-Speed, Dana, EV2
1971 340 Challenger Conv. Flemington Speedway Pace Car, FC7
1970 340 Six Pack Callenger T/A 4-speed T8 Tan
1971 340 Challenger RT Formal Roof, EV2 w/ V2 Stripe & Orange Houndstooth
1969 Talladega Torino, 428CJ
1969 Gurney Special Cyclone Spoiler II, 351 Cleveland
"Id rather have a bottle in front of me than a frontal lobotomy" Ben Franklin 1755
Re: Engine Noise - How to post a Video to Diagnose? [Re: RSI700VIPER] #2648725
04/25/19 09:45 AM
04/25/19 09:45 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
What engine?
Re: Engine Noise - How to post a Video to Diagnose? [Re: ScottSmith_Harms] #2648929
04/25/19 04:25 PM
04/25/19 04:25 PM
NW New Jersey
NW New Jersey
440 six pack
Re: Engine Noise - How to post a Video to Diagnose? [Re: RSI700VIPER] #2648938
04/25/19 04:45 PM
04/25/19 04:45 PM
ILL
Greentween Offline
Greentween  Offline
ILL
Put it on youtube and post a link to it here
Re: Engine Noise - How to post a Video to Diagnose? [Re: Greentween] #2648943
04/25/19 05:13 PM
04/25/19 05:13 PM
md
mopars4ever Online content
mopars4ever  Online Content
md
Auto trans? wouldn`t hurt to check the check torque converter bolts. Use a piece of hose to try and isolate where the sound is coming from.
Re: Engine Noise - How to post a Video to Diagnose? [Re: mopars4ever] #2648987
04/25/19 07:13 PM
04/25/19 07:13 PM
NW New Jersey
NW New Jersey
4-speed. I'll try posting on you-tube and link it.
Re: Engine Noise - How to post a Video to Diagnose? [Re: RSI700VIPER] #2648988
04/25/19 07:28 PM
04/25/19 07:28 PM
NW New Jersey
NW New Jersey
I'm unable to post it on you-tube, or even e-mail it to myself. File must be to large. GRRRRRR
Re: Engine Noise - How to post a Video to Diagnose? [Re: RSI700VIPER] #2648996
04/25/19 07:58 PM
04/25/19 07:58 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Total shot in the dark guess, but if its got a hydraulic cam there have been a LOT of hyd lifters going bad lately.
Re: Engine Noise - How to post a Video to Diagnose? [Re: ScottSmith_Harms] #2649016
04/25/19 08:41 PM
04/25/19 08:41 PM
Ohio
P
PDR Dude Offline
PDR Dude  Offline
P
Ohio
What is the history on the engine? Recent rebuild? Did the noise start out gradual and got worse? Did the noise start after running it hard or sitting for a long time? Just trying to help diagnose.....Scotts idea on the lifter is certainly a good possibility
Re: Engine Noise - How to post a Video to Diagnose? [Re: ScottSmith_Harms] #2649017
04/25/19 08:43 PM
04/25/19 08:43 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
What harmonic balancer is on the motor? A/C car?
Pulling the belts off would eliminate the alternator & water pump.
I'll assume you've already checked the fan & pulley for any wobble.
Does it sound like a bad bearing, or a rhythmic ticking, or contact between a rotating item and pan or tray?
Definitely from the front?
Does it change with clutch pushed in?
Might want to pull valve covers & poke around, though you said "middle front".
Re: Engine Noise - How to post a Video to Diagnose? [Re: ScottSmith_Harms] #2649018
04/25/19 08:44 PM
04/25/19 08:44 PM
NW New Jersey
NW New Jersey
Scott, it does (509) and it's relatively new, about 2 years old. I've had a bad lifter here and there, and it produced a ticking noise under the valve cover. The noise I'm hearing with this problem sounds more like a pre-ignition rattle. Very erratic, mid-lower front of motor. I'm about ready to pull the timing cover and pan. Sucks.
Re: Engine Noise - How to post a Video to Diagnose? [Re: RSI700VIPER] #2649022
04/25/19 08:49 PM
04/25/19 08:49 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Bummer but better to find out now than after further damage. Maybe a wrist pin. If you pull the plug wire to the offending cylinder while it's running the noise will likely stop if it's a bad pin.
Re: Engine Noise - How to post a Video to Diagnose? [Re: topside] #2649023
04/25/19 08:51 PM
04/25/19 08:51 PM
NW New Jersey
NW New Jersey
No wobble with fan or pulley.
Not rhythmic, more like an inconsistant rattle, like pre-ignition when you hammer down with crappy gas.
90% sure its from front.
Didn't check it with clutch engaged, good idea...
Re: Engine Noise - How to post a Video to Diagnose? [Re: ScottSmith_Harms] #2649029
04/25/19 08:54 PM
04/25/19 08:54 PM
NW New Jersey
NW New Jersey
Scott, pulled each plug wire one by one and noise remains. Although it got slightly louder when motor warmed up.
Re: Engine Noise - How to post a Video to Diagnose? [Re: PDR Dude] #2649032
04/25/19 08:57 PM
04/25/19 08:57 PM
NW New Jersey
NW New Jersey
Not sure of history on rebuild except it got a cam about 2 years ago. Only owned the car for a few months and the noise hasn't changed, but only put about 50 miles on the car.
Re: Engine Noise - How to post a Video to Diagnose? [Re: RSI700VIPER] #2649045
04/25/19 09:17 PM
04/25/19 09:17 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
When it got the cam
Was the oil slinger installed backwards on the crank ?
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: Engine Noise - How to post a Video to Diagnose? [Re: RSI700VIPER] #2649049
04/25/19 09:22 PM
04/25/19 09:22 PM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
Wonder if it's with the timing chain and/or oil slinger (assuming they put one on).
I had a video of what my Dakota sounded like when it's chain was hitting the cover, but, photobucket was kind enough to delete it for me. mad
If your video is only 15 seconds long and won't upload, it sounds like it's formatted wrong.
John
Re: Engine Noise - How to post a Video to Diagnose? [Re: SattyNoCar] #2649098
04/26/19 12:58 AM
04/26/19 12:58 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
What do the plugs look like?
If black, maybe carbon build-up on the piston giving a knock when warm...
Joe
Re: Engine Noise - How to post a Video to Diagnose? [Re: RSI700VIPER] #2649124
04/26/19 06:08 AM
04/26/19 06:08 AM
GMP440 Offline
GMP440  Offline
Go underneath and check the pulley to harmonic balancer bolts. You may have one or a couple bolts too long making them scrape against the timing case cover.
Had this happen on a 68 Roadrunner with 383. We did a new rebuild. On start up we get this noise we could not find.
With the engine off, went underneath , noticed that the pulley to harmonic balancer bolts were too long and scraping the cover. We put shorter bolts on and no more noise.
Re: Engine Noise - How to post a Video to Diagnose? [Re: GMP440] #2649359
04/26/19 05:11 PM
04/26/19 05:11 PM
NW New Jersey
NW New Jersey
After a new rebuild and learning it was just a bolt... wow that stinks. I'll check the bolts tonight.
