BEST BATTERY FOR TRAILER WINCH #2648489
04/24/19 02:59 PM
04/24/19 02:59 PM
South Park, Pa.
68LAR Offline OP
68LAR  Offline OP
South Park, Pa.
What is the best bang for the buck for a trailer winch? I had been using a Dyna-Batt. It gave up the ghost over the winter. Will hold 10.95 volts, no more. Charged it for three days straight on 2 amp setting...Need another, but don't want to spend $2-300 for one.. Any suggestions??
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: BEST BATTERY FOR TRAILER WINCH [Re: 68LAR] #2648498
04/24/19 03:06 PM
04/24/19 03:06 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
How much do you use the winch? Everytime you load and unload the car? If you use it sparingly, I use my jump box. Just a suggestion.
Re: BEST BATTERY FOR TRAILER WINCH [Re: 68LAR] #2648506
04/24/19 03:19 PM
04/24/19 03:19 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I bought a big RV battery from Walmart for around 100.00 last year. Two year guarantee. I use it for my inverter in my Trailer too
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: BEST BATTERY FOR TRAILER WINCH [Re: pittsburghracer] #2648521
04/24/19 03:43 PM
04/24/19 03:43 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
hi
repeated discharging you will need a deep cycle RV battery NAPA 8240, drawtite hitches sells a kit to keep battery charged from tow vehicle
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: BEST BATTERY FOR TRAILER WINCH [Re: 440lebaron] #2648551
04/24/19 05:05 PM
04/24/19 05:05 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I have a take out Mercedes Benz battery in my older trailer for 10 years and it is still working like it did day one. That battery is out of an 05 CLS500. I don't charge it unless the generator is on in the trailer..My new trailer came with a deep cycle Interstate and so far so good but only a few moths old.
Re: BEST BATTERY FOR TRAILER WINCH [Re: Al_Alguire] #2648562
04/24/19 05:55 PM
04/24/19 05:55 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Good Group 27 Deep Cycle. Interstate is good.
Re: BEST BATTERY FOR TRAILER WINCH [Re: CMcAllister] #2648611
04/24/19 08:51 PM
04/24/19 08:51 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I pull the 10 year old optima blue top out of the wife’s boat. It also gets used to run my water pump/rad fan between rounds. No idea why this battery is still alive.
Re: BEST BATTERY FOR TRAILER WINCH [Re: J_BODY] #2648616
04/24/19 09:09 PM
04/24/19 09:09 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Depends on how your truck is wired.. I have a battery isolator with
a deep cycle for the winch.. when then the truck is running it will
charge the deep cycle
wave
Re: BEST BATTERY FOR TRAILER WINCH [Re: MR_P_BODY] #2648634
04/24/19 09:36 PM
04/24/19 09:36 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I just use a Group 24 that's in a battery box on the trailer, which I keep a battery maintainer on when the trailer's parked.
But usually, that battery & winch are also plugged into my Dually.
I use a plug at its back bumper that comes off its battery, or I can loop the trailer end to another plug that comes off the winch.
When the Dually's running, it can charge both batteries.
Reason I did it that way is in case I'm using the trailer behind something else instead of the Dually; I can still use the winch via the trailer battery.
Re: BEST BATTERY FOR TRAILER WINCH [Re: 68LAR] #2648647
04/24/19 10:15 PM
04/24/19 10:15 PM
Buy a good group 27 RV/Marine deep cycle up
Does your truck charge it when towing? Do you have a generator for the trailer that will charge it also? If no to both you need to remember to charge it when it gets down near 12.25 Volts up
Re: BEST BATTERY FOR TRAILER WINCH [Re: nss guy] #2648717
04/25/19 09:06 AM
04/25/19 09:06 AM
South Park, Pa.
68LAR Offline OP
68LAR  Offline OP
South Park, Pa.
I don't use it very much. As a matter of fact, I had to use it for the first time in about three years, a few weeks ago. I had charged it a few times prior to that usage. I don't have it hooked up to my truck charging system. It is a stand alone battery that I have been charging after usage with a Battery Tender.
Re: BEST BATTERY FOR TRAILER WINCH [Re: 68LAR] #2648718
04/25/19 09:15 AM
04/25/19 09:15 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
For that app a deep cycle is usually ideal but it looks like yours isn't the usual scenario and sitting for years between uses is hell on any battery.
The best bang for the buck as far as a new powerful battery goes is head to your nearest big truck dealer, Kenworth etc, and pick up a cranking battery. They are usually about $80 +/- and up to 1100 cold cranking amps.
Kevin
Re: BEST BATTERY FOR TRAILER WINCH [Re: 68LAR] #2648719
04/25/19 09:16 AM
04/25/19 09:16 AM
MR_P_BODY Offline
MR_P_BODY  Offline
A nice size deep cycle will cover your needs.. it will hold better power
before falling off
wave
Re: BEST BATTERY FOR TRAILER WINCH [Re: Twostick] #2648960
04/25/19 05:56 PM
04/25/19 05:56 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
I have a suction cupped solar panel. I didn't think it was a good idea to expose it to the brutal Minnesota winters, so I removed the battery for winter. The panel seems to help at the track. I'll know more this season.
Re: BEST BATTERY FOR TRAILER WINCH [Re: Leigh] #2649156
04/26/19 08:44 AM
04/26/19 08:44 AM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
I have a Duracell (Made in the USA) Marine/RV battery from Sam's Club in my car hauler. Works great. Charge as needed in season, pull and store on shop bench with a Battery Tender during the winter.
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: BEST BATTERY FOR TRAILER WINCH [Re: DynoDave] #2649312
04/26/19 02:22 PM
04/26/19 02:22 PM
South Park, Pa.
68LAR Offline OP
68LAR  Offline OP
South Park, Pa.
I don't belong to Sams club, but my daughter does. What was the cost of your battery??
Re: BEST BATTERY FOR TRAILER WINCH [Re: 68LAR] #2649317
04/26/19 02:38 PM
04/26/19 02:38 PM
PA.
"Little"John
"Little"John
PA.
I think that was the brand I bought from Walmart
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: BEST BATTERY FOR TRAILER WINCH [Re: pittsburghracer] #2649329
04/26/19 03:24 PM
04/26/19 03:24 PM
La.USA
rick4106 Offline
rick4106  Offline
La.USA
i use a regular 24 series battery and tie into power from tow rig to charge while towing. warranty better on car battery then deep cycle. lol
Re: BEST BATTERY FOR TRAILER WINCH [Re: rick4106] #2649342
04/26/19 04:08 PM
04/26/19 04:08 PM
PA.
"Little"John
"Little"John
PA.
Nope I was wrong it’s an Ever Start Max RV battery from Walmart
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: BEST BATTERY FOR TRAILER WINCH [Re: 68LAR] #2649353
04/26/19 05:00 PM
04/26/19 05:00 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
1 time in 3 years, something like this might be more useful.
