mechanical fuel inj. nozzles #2648590
04/24/19 07:58 PM
04/24/19 07:58 PM
Nevada
merpar Offline OP
merpar  Offline OP
Nevada
For the mechanical fuel inj. Gurus. The nozzles I have are a Waterman #51= .028 and running methanol. I would like to clean the system out by running race gas through it. Am looking for a ball park size on nozzles to run it on race gas. Any help is appreciated. Thank you guys.
Re: mechanical fuel inj. nozzles [Re: merpar] #2648604
04/24/19 08:30 PM
04/24/19 08:30 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
Its not that simple...for clean out just run it til it stumbles then your good. Define "run it on race gas"? just for clean out?
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: mechanical fuel inj. nozzles [Re: W.I.N. Racing] #2648660
04/24/19 11:01 PM
04/24/19 11:01 PM
Nevada
merpar Offline OP
merpar  Offline OP
Nevada
Just to clean out the system so I don't get methanol crystals. Have tried it before as you state, till it blubers. But won't run long enough to clean it out completely.
Re: mechanical fuel inj. nozzles [Re: merpar] #2648839
04/25/19 12:46 PM
04/25/19 12:46 PM
Does the top end lube for alcohol stop the crystals forming?
If so are you using it?
Re: mechanical fuel inj. nozzles [Re: Cab_Burge] #2648915
04/25/19 03:54 PM
04/25/19 03:54 PM
Nevada
merpar Offline OP
merpar  Offline OP
Nevada
Yes, I am using the top end lube. But past experience it helps but just prolongs the transaction. If I were running hilborn or another stack injection. I would just run the gas through until it got rich and died. But I'm running an Injectorator and it has float bowls and excellerator pumps. So it just won't run long enough to displace all the methanol. I'm thinking I may just buy some brass and make some nozzles with a 35 to 40% smaller hole. But not a fuzzy feeling trying to drill an .018 hole in 8 pieces.
Re: mechanical fuel inj. nozzles [Re: merpar] #2648953
04/25/19 05:34 PM
04/25/19 05:34 PM
Central TEXAS!!!!
sr4440 Online content
sr4440  Online Content
Central TEXAS!!!!
to answer your question 8ea .028 nozzles are .004926 sq inches
8 ea .020 nozzles are .002513 sq inches
8 ea .019 nozzles are .002268 sq inches
Joe
Without Data, you’re just another guy with an opinion.
Re: mechanical fuel inj. nozzles [Re: sr4440] #2649004
04/25/19 08:26 PM
04/25/19 08:26 PM
Nevada
merpar Offline OP
merpar  Offline OP
Nevada
Thank you sr4440, Your figures tell me I could probably go with a .022 to .023 hole. I'm sure it would run long enough to displace the methanol. Thank you.
Re: mechanical fuel inj. nozzles [Re: merpar] #2649272
04/26/19 12:46 PM
04/26/19 12:46 PM
Franklin, TN
23T Hemmee Offline
23T Hemmee  Offline
Franklin, TN
Assuming you've got a 3-way mechanical fuel shut-off, start it and immediately start pulling back on the shut-off slowly bypassing fuel back to the tank. Idle will increase and temp will too, so don't pull back too far, but 15-20 seconds or so should clean out most gunk buildup, Definitely a trial and error method, better to lean too slowly than too quickly.
BTW the crystals form in old alky, top lube won't help there
Ronny
6.789 @ 198.63 **.956 Brand New 60'***
4.17@ 169 1/8th mile
John 14:6
https://www.youtube.com/watch?v=TUku_hjYRh8
Re: mechanical fuel inj. nozzles [Re: 23T Hemmee] #2649301
04/26/19 01:56 PM
04/26/19 01:56 PM
Franklin, TN
23T Hemmee Offline
23T Hemmee  Offline
Franklin, TN
Sorry, just saw that you're running the injectorator. The above obviously won't work.... blush
Ronny
John 14:6
Milodon [Re: 23T Hemmee] #2666966
06/17/19 05:36 PM
06/17/19 05:36 PM
INTERNATIONAL
19581021 7132 Offline
INTERNATIONAL
Hi Ronny, did you still have any parts to the milodon hemi block?
Re: Milodon [Re: 19581021 7132] #2667184
06/18/19 01:07 PM
06/18/19 01:07 PM
Franklin, TN
23T Hemmee Offline
23T Hemmee  Offline
Franklin, TN
No, sorry, sold the last sleeve, stud, etc. everything I could salvage to a member on here, Oyvind Mopar, several years ago. Havn't seen him post in a long time, don't know if he ever got it together or not, or if he is still on here.
Ronny
John 14:6
