3.54 vs 3.73 performance difference #2648597
04/24/19 08:10 PM
04/24/19 08:10 PM
clarks summit pa
73cuda340 Offline OP
clarks summit pa
Has anybody done a comparison between 3.54 and 3.73 gears in the 1/4? I'm getting a new Dana 60 for my cuda but I'm unsure about which ratio to go with. Car is street/ strip but no highway driving, just around town and back roads. Car has 528 Hemi with a 4 speed and 295/55/15s.
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip, (JA5) Silver Frost Metallic 1973 Challenger Rallye 340 1985 W150 Power Ram prospector 1986 Camaro IROC-Z 305 tpi
Re: 3.54 vs 3.73 performance difference [Re: 73cuda340] #2648600
04/24/19 08:26 PM
04/24/19 08:26 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
not enough to notice on the street
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: 3.54 vs 3.73 performance difference [Re: 73cuda340] #2648648
04/24/19 10:18 PM
04/24/19 10:18 PM
If it was me I would buy the 3:73 for the stick tranny, 3:54 for a 727 up
is your tranny a NP833 standard ratio, non O.D.,or which tranny are you using and what is the first gear ratio?
Re: 3.54 vs 3.73 performance difference [Re: Cab_Burge] #2648699
04/25/19 08:06 AM
04/25/19 08:06 AM
an8sec70cuda Offline
iagree Not enough to notice. I'd probably go with the 3.73 though. twocents
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 3.54 vs 3.73 performance difference [Re: 73cuda340] #2648709
04/25/19 08:19 AM
04/25/19 08:19 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
iagree Not much difference. On a street car, I would be more interested in whether one set would be quieter than the other. Lots and lots of noisy gear sets out there nowadays. Dr. Diff is the go-to guy on these matters. Here is a good calculator for you:
http://www.wallaceracing.com/calc-gear-tire-rpm-mph.php
Master, again and still
Re: 3.54 vs 3.73 performance difference [Re: 73cuda340] #2648743
04/25/19 10:06 AM
04/25/19 10:06 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
No highway use, street/strip........
If the ET is a factor in deciding on which gears, I’d probably go 4.10’s with a stick.
Re: 3.54 vs 3.73 performance difference [Re: fast68plymouth] #2648791
04/25/19 11:31 AM
04/25/19 11:31 AM
TN
1DGEMAN Offline
1DGEMAN  Offline
TN
Since you are just putting around back roads and no freeway driving put the gears in it that work the best for the strip. At least 4.10's
Real Men shift for themselves
Re: 3.54 vs 3.73 performance difference [Re: 73cuda340] #2648823
04/25/19 12:21 PM
04/25/19 12:21 PM
central il.
second 70 Offline
second 70  Offline
central il.
I changed from a 3:54 to 4:10 on my hemi cuda and it only raised the rpm at 70mph 500. It's a 426 4speed and has 28" tall tires. It is a lot more fun to drive now.
Re: 3.54 vs 3.73 performance difference [Re: second 70] #2648827
04/25/19 12:25 PM
04/25/19 12:25 PM
clarks summit pa
clarks summit pa
My car has a 71 18 spline hemi 4 speed which should be a 2.44 first gear.
Re: 3.54 vs 3.73 performance difference [Re: 73cuda340] #2648842
04/25/19 12:50 PM
04/25/19 12:50 PM
I thought all the 18 spline hemi tranny had either the 2.65(red stripe?) or 2.66 (blue stripe?)first gear ratio, no close ratio like in the 1970 23 spline AAR and T/A and in the 1971 and later 23 spline tranny in production vehicles confused
Re: 3.54 vs 3.73 performance difference [Re: 73cuda340] #2648843
04/25/19 12:51 PM
04/25/19 12:51 PM
Graz, Austria
DGS Offline
DGS  Offline
Graz, Austria
I would go with the 3.73 then. Starting line ratio is about 9.1 vs. 8.6 with the 3.54 gears.
Re: 3.54 vs 3.73 performance difference [Re: 73cuda340] #2649005
04/25/19 08:29 PM
04/25/19 08:29 PM
Prospect, PA
BSB67 Online content
BSB67  Online Content
Prospect, PA
Has anybody done a comparison between 3.54 and 3.73 gears in the 1/4? .........Car has 528 Hemi with a 4 speed and 295/55/15s.
No, I have not done a comparison. In your question above, will the car have street tires, or slicks?
Generally, from my experience, traction limited cars (i.e. street tires at the track) usually show little change in ET because the benefit of the higher gear is lost in the lack of improvement in 60 ft due to the traction limitation of the tire.
But if the car will never be on the highway, why would you not go with the higher gear ratio. It will be more fun to drive.
Re: 3.54 vs 3.73 performance difference [Re: Cab_Burge] #2649571
04/27/19 03:41 PM
04/27/19 03:41 PM
clarks summit pa
clarks summit pa
I could be wrong, but I read that 70 and earlier hemi 4 speeds had the 2.65 and the 71 had the other.
Re: 3.54 vs 3.73 performance difference [Re: 73cuda340] #2649669
04/27/19 09:09 PM
04/27/19 09:09 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Of them 2 selections with a 528 Hemi I would go with the 3.73's. Good luck , Ron
Re: 3.54 vs 3.73 performance difference [Re: BSB67] #2649811
04/28/19 10:21 AM
04/28/19 10:21 AM
clarks summit pa
clarks summit pa
The car has drag radials on it.
Re: 3.54 vs 3.73 performance difference [Re: 73cuda340] #2649878
04/28/19 01:06 PM
04/28/19 01:06 PM
Mopar added the close ratio to the 23 spline trannys in 1970 on the AAR and T/A cars, they then drop the 2.66,265, ratio in the 23 spline tranny only (is what I'm under the impression) and put the close ratio trannys in all the 1971 4 speed cars except the Hemi and 440 HP cars confused
I've never had a 1971 hemi or 440 18 spline tranny to check the first gear ratio, maybe some one here who has one can chime in work
Re: 3.54 vs 3.73 performance difference [Re: 73cuda340] #2649882
04/28/19 01:14 PM
04/28/19 01:14 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Welcome to the slippery slope! I originally just wanted a good 4-barrel on my 383 Satellite..... haha.
Re: 3.54 vs 3.73 performance difference [Re: StealthWedge67] #2649980
04/28/19 07:26 PM
04/28/19 07:26 PM
clarks summit pa
clarks summit pa
Re: 3.54 vs 3.73 performance difference [Re: 73cuda340] #2650043
04/28/19 10:43 PM
04/28/19 10:43 PM
http://www.brewersperformance.com/history.php
https://www.allpar.com/mopar/transmissions/four-speed-manual.html
Here's the two sources where it lists the 2.44 first gear ratio for 1971.
Those are the first and only things I've seen in writing about the 18 spline 1st gear ratio being change for 1971 bow blush
Re: 3.54 vs 3.73 performance difference [Re: Cab_Burge] #2650246
04/29/19 03:17 PM
04/29/19 03:17 PM
Gilroy,CA.
mopardude318 Offline
Gilroy,CA.
This leads me to a question, I currently have 3.73s in a Dana 60, would the jump to 4.10s be substantial? Currently have an OD trans.
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
