PB, 68 Charger #2647288
04/20/19 03:18 PM
04/20/19 03:18 PM
Pattison Texas
CSK Offline OP
CSK  Offline OP
Pattison Texas
Well new slip on the right, I ran 11.11, picked up 2mph in the 1/8 & lost 2mph in the 1/4, when I hit high gear it just laid down, fuel problem ? trans ? will figure it out. Race weight 4050lbs drove 130 miles round trip. I am so mad at myself, I did not look at my AFR gauge when it happened. 4 hours one run
Re: PB, 68 Charger [Re: CSK] #2647330
04/20/19 05:40 PM
04/20/19 05:40 PM
Pattison Texas
CSK Offline OP
CSK  Offline OP
Pattison Texas
Re: PB, 68 Charger [Re: CSK] #2647337
04/20/19 06:06 PM
04/20/19 06:06 PM
Sydney,Australia
tex013 Online content
tex013  Online Content
Sydney,Australia
Nice gain ..
May also be lack of gear causing it to lay over
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: PB, 68 Charger [Re: tex013] #2647347
04/20/19 06:33 PM
04/20/19 06:33 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Why such a big difference in the 60 foot. It all starts there.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: PB, 68 Charger [Re: pittsburghracer] #2647349
04/20/19 06:46 PM
04/20/19 06:46 PM
Pattison Texas
CSK Offline OP
CSK  Offline OP
Pattison Texas
The 1.66 was off idle & bad track prep
Re: PB, 68 Charger [Re: CSK] #2647351
04/20/19 06:56 PM
04/20/19 06:56 PM
PA.
"Little"John
"Little"John
PA.
Ohhhh. That makes sense. Nice pick up and once you get her figured out looks like another new best in your future. Hurry up before you lose that good air
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: PB, 68 Charger [Re: pittsburghracer] #2647442
04/21/19 01:12 AM
04/21/19 01:12 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Nice going ! Get that top end fixed and you have a 10 second car. For a reference here is one of my 10.76 passes. You did good. What size fuel line you running and what fuel pump ? Congrats on the new best also. Ron
Re: PB, 68 Charger [Re: 383man] #2647448
04/21/19 01:30 AM
04/21/19 01:30 AM
Pattison Texas
CSK Offline OP
CSK  Offline OP
Pattison Texas
Its a tanks inc EFI set up with a return running a carb ,255lph 3/8supply,3/8 return . 6 psi it is supposed to be good for 800 hp
Re: PB, 68 Charger [Re: CSK] #2647451
04/21/19 01:52 AM
04/21/19 01:52 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Sounds like you should have that handled. Good luck with it. Ron
Re: PB, 68 Charger [Re: 383man] #2647457
04/21/19 02:10 AM
04/21/19 02:10 AM
Pattison Texas
CSK Offline OP
CSK  Offline OP
Pattison Texas
Thanks Ron !!
Re: PB, 68 Charger [Re: CSK] #2647543
04/21/19 12:28 PM
04/21/19 12:28 PM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
Awesome, Charlie! Hopefully I can get mine out and start chasing your times this summer. But it won't be nearly as well sorted out...
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: PB, 68 Charger [Re: OhioMopar] #2647570
04/21/19 02:33 PM
04/21/19 02:33 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I forgot that thing was EFI.
I would think it would be even more important to insure the fuel pressure is constant with that set up.
What system are you running that operates at only 6psi(or did you mean 60psi)?
Edit: looking at the specs for the Walbro 255 pump, I’d say you’re at the point where it may just not be enough pump.
It’s rated for 630hp........ going by this:
Re: PB, 68 Charger [Re: fast68plymouth] #2647583
04/21/19 04:09 PM
04/21/19 04:09 PM
Pattison Texas
CSK Offline OP
CSK  Offline OP
Pattison Texas
Yes that is the pump I have, it is still Carbed, running a 6psi adjustable return regulator. it is an EFI set up tank, will go EFI as money allows
Re: PB, 68 Charger [Re: 383man] #2647597
04/21/19 06:22 PM
04/21/19 06:22 PM
So. Burlington, Vt.
So. Burlington, Vt.
I wound def flow test the system and make sure you have the flow you think you do.
Re: PB, 68 Charger [Re: fast68plymouth] #2647606
04/21/19 06:49 PM
04/21/19 06:49 PM
Cab_Burge Online work
Cab_Burge  Online Work
iagree scope
NEVER ASSUME( Ass U Me whistling) anything on race parts, NEVER tsk
Re: PB, 68 Charger [Re: Cab_Burge] #2647616
04/21/19 07:25 PM
04/21/19 07:25 PM
Pattison Texas
CSK Offline OP
CSK  Offline OP
Pattison Texas
iagree scope
will do tomorrow smile
Re: PB, 68 Charger [Re: CSK] #2647773
04/22/19 10:53 AM
04/22/19 10:53 AM
Pattison Texas
CSK Offline OP
CSK  Offline OP
Pattison Texas
Good Morning, I just did a fuel pump volume test, please correct me if I am wrong, it took 41 seconds for 1 qt @ 6psi, my math says my fuel system is only putting out 21.95 GPH, if thats the case it would explain a lot.
Thanks Charlie
Re: PB, 68 Charger [Re: CSK] #2647788
04/22/19 11:19 AM
04/22/19 11:19 AM
So. Burlington, Vt.
So. Burlington, Vt.
If you did the test right....... then just under 22gph is what I get for 1qt in 41 seconds.
I assume you tapped into the system from the line that feeds the carb, installed a valve on the end of the line, turn on the pump and close down the valve to achieve 6psi system pressure.
Then time the flow.
I would try it at 5, 4, 3 psi as well, just to see how low the system pressure would have to be to flow the fuel you need (50-55gph).
My experience has been that when flowing the entire system, while maintaining the required system pressure....... you need something like a 140gph pump....... for your power level(600-650hp).
I have seen many systems not pass this test when fuel pumps that are marginally suitable are used.
The question now is, is it the pump...... or a restriction in the line/system?
Did you see what the free flow was?
I know of one instance where the free low was more than adequate, but when tested at 6si, there was barely a dribble coming through(about 6mins to fill a gallon can).
Re: PB, 68 Charger [Re: CSK] #2647790
04/22/19 11:22 AM
04/22/19 11:22 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Such a cool car, one of my favorites here.
Fuel flow doesn't sound like quite enough!
Rich H.
Esse Quam Videri
Re: PB, 68 Charger [Re: ZIPPY] #2647813
04/22/19 12:33 PM
04/22/19 12:33 PM
Pattison Texas
CSK Offline OP
CSK  Offline OP
Pattison Texas
Thank you Zippy
