Good drag race only Powerglide shifter? #2646250
04/17/19 10:15 PM
04/17/19 10:15 PM
Cab_Burge Offline OP
I have a customer who wants to buy a good Power Glide drag race shifter that he can put a RPM activated electric solenoid on it to make it shift from the RPM module help
I have a older Phantom, now owned by Biondo and sold under their name now, shifter with a Shift Noid CO2 operated RPM activated solenoid on it that works good but he doesn't want the bottle and lines in his car.
Is the Precision brand ,PPP, better than most of the other bigger brands like B&M and Hurst shifters ? help
All help and comments welcomed up
Re: Good drag race only Powerglide shifter? [Re: Cab_Burge] #2646272
04/17/19 11:08 PM
04/17/19 11:08 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
I also have a Phantom that I bought from John when he first came out with them. Great shifter. Biondo has that style shifter available with electric along with the Pro Stick/Quarter Stick style and some others. PPP does an electric unit and Shifnoid sells add on kits for a number of shifters. Never used an electric unit myself. We had CO2 running multiple things in the car, so it was an easy decision.
Re: Good drag race only Powerglide shifter? [Re: Cab_Burge] #2646273
04/17/19 11:09 PM
04/17/19 11:09 PM
Livermore, CA
Dduster Offline
Dduster  Offline
Livermore, CA
Cab, take a look at Turbo Action with reverse pattern p!ate. Race tested, works good with Dedenbear electric shift solenoid hardware. Match gate plate with transbrake.
Re: Good drag race only Powerglide shifter? [Re: Dduster] #2646298
04/18/19 01:05 AM
04/18/19 01:05 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
I just changed the gate on my Cheetah shifter. I had to turn the Dedenbear bracket upside down and tap the shifter arm for a bolt to ram against. Had some bugs that got worked out in short order. I also run an upside down bracket on the PG so the shifter now front exits and shifts forward. The ratio is super important. I've seen multiple PG's that guys had the wrong ratio and it would work fine but Park wouldn't always engage. I just didn't want to re-fab the car and spend 400 bucks on a new shifter.
Re: Good drag race only Powerglide shifter? [Re: Cab_Burge] #2646345
04/18/19 07:43 AM
04/18/19 07:43 AM
HR3128 Offline
HR3128  Offline
Here's my set-up. Hurst QuarterStick & Shiftnoid solenoid. It's worked good for me.
Re: Good drag race only Powerglide shifter? [Re: HR3128] #2646350
04/18/19 08:09 AM
04/18/19 08:09 AM
an8sec70cuda Offline
Same thing in the Camaro I drive that we used to run 6.0 index (1/8 mile) classes with. Has worked flawless for years.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Good drag race only Powerglide shifter? [Re: an8sec70cuda] #2646467
04/18/19 12:41 PM
04/18/19 12:41 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
We have a PPP in the door car and a Bandit in the dragster. Dragster is electric door car is air.
Re: Good drag race only Powerglide shifter? [Re: Al_Alguire] #2646472
04/18/19 01:08 PM
04/18/19 01:08 PM
Fulton County, PA
Mr. Helpful
Mr. Helpful
Fulton County, PA
While the Hurst Quarter Stick and B&M Pro Stick are similar and both work well (I used a Quarter Stick with the 3 speed and liked it after replacing the cheesy cable) the B&M comes with a true Morse cable and nicer hardware. A least it did the last time I had one in my hands.
Re: Good drag race only Powerglide shifter? [Re: CMcAllister] #2646566
04/18/19 06:19 PM
04/18/19 06:19 PM
Yes
sixpakdodge Offline
sixpakdodge  Offline
Yes
I have a Quarter Stick with a Biondo solenoid in one car, and a Turbo Action shifter with a Biondo solenoid in the other. Both electric solenoids, and have never had any issues with either. I'm more comfortable with the solenoid on the Quarter Stick, than smacking the plastic on the TA shifter though.
