Repair crank seal surface? #2646420
04/18/19 10:44 AM
04/18/19 10:44 AM
Milwaukee WI
TRENDZ Offline OP
TRENDZ  Offline OP
Milwaukee WI
I’ve repaired crank snouts with hard chroming, but I am not so sure it would be the best solution for the rear main seal area. I’ve read that hard chroming creates embrittlement in the base metal being plated. Not a good situation considering all the power is going through that journal.
I never had anything spray welded. It sounds like that may be an alternative. I was also thinking about turning it down, and running a rope seal.
This is a 331 hemi.
Re: Repair crank seal surface? [Re: TRENDZ] #2646421
04/18/19 10:50 AM
04/18/19 10:50 AM
Cab_Burge Online work
Cab_Burge  Online Work
I would try polishing it enough to try and remove the high spots and go from there. scope
None of the early Hemi had the later seals, all came with rope seals work
There might be a later seal (273/360)the same size that might work scope Especially one of the Viton or Teflon seals work luck
Re: Repair crank seal surface? [Re: Cab_Burge] #2646440
04/18/19 11:42 AM
04/18/19 11:42 AM
Deland, Florida
biff426 Offline
biff426  Offline
Deland, Florida
Had one fixed a year or two ago they welded it up and ground it looked just like one of the aftermarket cranks. Cost about $180 at a crank shop sealed great no issues. The hash marks are gone but the aftermarket cranks don't have them anyway.
Re: Repair crank seal surface? [Re: TRENDZ] #2646446
04/18/19 11:51 AM
04/18/19 11:51 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I had a crank shop spray weld a crank.. that end journal is stronger
than a rod journal(diameter of it)
That weld job was on a 4 cyl diesel that ate a crank
wave
Re: Repair crank seal surface? [Re: MR_P_BODY] #2646463
04/18/19 12:34 PM
04/18/19 12:34 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Hard-chroming is also an option.
Re: Repair crank seal surface? [Re: John_Kunkel] #2646477
04/18/19 01:48 PM
04/18/19 01:48 PM
Milwaukee WI
TRENDZ Offline OP
TRENDZ  Offline OP
Milwaukee WI
Does anyone know the size of a rear main seal journal for a small block? Maybe that is an option. I assumed that the seal hot heads sells is out of some standard common engine (Its only $14.00)
Just by looks, I would say .020” would most likely clean it up.
Has anyone ever made an undersized seal ?
Re: Repair crank seal surface? [Re: TRENDZ] #2646517
04/18/19 04:10 PM
04/18/19 04:10 PM
Spring Hill Fl
65Fury440 Offline
65Fury440  Offline
Spring Hill Fl
https://www.fmmotorparts.com/fmstorefront/federalmogul/en/USD/Gaskets-%26-Sealing-Systems/Gaskets-%26-Sealing/c/Gaskets%20Sealing%20Systems
Might try tech support here. If you get someone knowledgeable on the phone, he may get you to what you need.
Re: Repair crank seal surface? [Re: TRENDZ] #2646520
04/18/19 04:21 PM
04/18/19 04:21 PM
MR_P_BODY Offline
MR_P_BODY  Offline
FYI.. that welding process is called spray transfer.. I was taught that
back when I was in welding school .. its how you set up the machine
but you run it hot
wave
Re: Repair crank seal surface? [Re: MR_P_BODY] #2646661
04/18/19 11:41 PM
04/18/19 11:41 PM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
i have run several with seal surface .010 us and std seal .!
Re: Repair crank seal surface? [Re: MR_P_BODY] #2647086
04/20/19 02:31 AM
04/20/19 02:31 AM
Btween a rock and a hard place
moparlulu Offline
moparlulu  Offline
but you run it hot
wave
. This isn't quite the same mr P, they introduce powdered metal into a plasma stream that transfers to the grounded part if I'm not mistaken. I'd bet it would work fine.
