Holley 80688 Dominator #2644756
04/13/19 02:33 PM
04/13/19 02:33 PM
Md.
carnut68 Offline OP
carnut68  Offline OP
Md.
Anyone have any experience with this carb? Good/bad?
America First!
Re: Holley 80688 Dominator [Re: carnut68] #2644947
04/14/19 09:46 AM
04/14/19 09:46 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Put one on my buddies street car, worked ok. no complaints. I remember changing a transfer slot restriction though.
Re: Holley 80688 Dominator [Re: B1MAXX] #2644981
04/14/19 11:14 AM
04/14/19 11:14 AM
Md.
carnut68 Offline OP
carnut68  Offline OP
Md.
Thanks for the input. Must not be too many guys using them. Looks like a good deal with the Jegs discount. If the description is right it looks to be fully tunable.
America First!
Re: Holley 80688 Dominator [Re: carnut68] #2645010
04/14/19 12:11 PM
04/14/19 12:11 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Have you thought about talking to Dom (ThumperDart) about a new Dominator?
https://www.facebook.com/search/top/?q=dominic%20thumper&epa=SEARCH_BOX
Master, again and still
Re: Holley 80688 Dominator [Re: DaveRS23] #2645012
04/14/19 12:19 PM
04/14/19 12:19 PM
Md.
carnut68 Offline OP
carnut68  Offline OP
Md.
He helped me with 4150 /950. Its much better. Haven't seen him post in quite a while.
America First!
Re: Holley 80688 Dominator [Re: carnut68] #2645057
04/14/19 03:04 PM
04/14/19 03:04 PM
Washington
madscientist Offline
Washington
He is hanging out of Facebook more these days.
Re: Holley 80688 Dominator [Re: carnut68] #2645366
04/15/19 12:25 PM
04/15/19 12:25 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
They are very nice looking too. If it's a race app. I would give it the definite thumbs up. I put it on a 3.54 geared street car. It didn't hesitate a bit Just to fat at cruise.
Re: Holley 80688 Dominator [Re: madscientist] #2645763
04/16/19 06:07 PM
04/16/19 06:07 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Last time we spoke, he was pretty much done with the rest of the interweb outside of FB.
Re: Holley 80688 Dominator [Re: B1MAXX] #2645766
04/16/19 06:11 PM
04/16/19 06:11 PM
BradH Offline
BradH  Offline
I'd be interested in knowing the full calibration, assuming it's a 2-circuit, and how much adjustability remains from the more expensive versions.
Re: Holley 80688 Dominator [Re: carnut68] #2645859
04/16/19 10:17 PM
04/16/19 10:17 PM
Is it a 80688 or a 80868 List #?
Re: Holley 80688 Dominator [Re: Cab_Burge] #2645870
04/16/19 10:38 PM
04/16/19 10:38 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
You're not going to beat Dom's new billet pieces for quality. He just got some new billet fuel bowls, too.
Re: Holley 80688 Dominator [Re: carnut68] #2645912
04/17/19 02:37 AM
04/17/19 02:37 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
got one on my big block . Good adjustment , emulsion is just drilled .
I lowered the IFR and made transfer slot adjustable .
Just waiting to go back on my 505 , will change PVCR to bigger jet blanks and need to go a little bigger size . Fine on my 440 though I have left it with the 505 tune so a little fat
Oh yeah don't forget it is 5/16"taller than older 4500's
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Holley 80688 Dominator [Re: carnut68] #2645938
04/17/19 08:07 AM
04/17/19 08:07 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
You can contact Dom on facebook"Thumpercarbs". He can sure tune a Dominator for street/strip. Builds some real nice stuff.
Re: Holley 80688 Dominator [Re: BradH] #2646037
04/17/19 12:19 PM
04/17/19 12:19 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
as I recall I pulled the transfer-slot restrictions, tapped the body , put in quick fuel .052's and had 13.1-13.2 @ cruise.
Re: Holley 80688 Dominator [Re: sgcuda] #2646038
04/17/19 12:22 PM
04/17/19 12:22 PM
BradH Offline
BradH  Offline
They're sweet, but you're not going to get one of those for $800, either.
Re: Holley 80688 Dominator [Re: BradH] #2646167
04/17/19 06:39 PM
04/17/19 06:39 PM
sgcuda Offline
sgcuda  Offline
Brad, I've seen some of the jewelry that you've built. You, of all people, know that you get what you pay for.
Re: Holley 80688 Dominator [Re: B1MAXX] #2646251
04/17/19 10:17 PM
04/17/19 10:17 PM
You might llke a leaner AFR like from 14.3 to 15.5 AFR at light part throttle cruise than the richer one you have now scope up
I did grin
Re: Holley 80688 Dominator [Re: sgcuda] #2646292
04/18/19 12:16 AM
04/18/19 12:16 AM
BradH Offline
BradH  Offline
No argument on that point. However, I've wondered how good a carb I could build on the cheap, too. It doesn't have to look fancy to be effective.
Re: Holley 80688 Dominator [Re: BradH] #2646447
04/18/19 11:51 AM
04/18/19 11:51 AM
AndyF Offline
AndyF  Offline
A production type carb can be very cheap since the engineers figured out what all the hole sizes need to be. It is the adjust ability that costs money. I've looked at the Dominator in question and it would probably work just fine as long as your engine is in the sweet spot of what it is designed for. The Holley engineers took out some of the features but it looks like they left most of the adjustments. I'm sure that carb would work just fine on most bracket engines but I doubt you'll see them on any Comp Eliminator cars.
I was helping dyno test a 540 inch BB Ford the other day and one thing we did was try some different Dominator carbs. The carbs were all over the place in terms of power and power curves even if the AFR was all the same. Just totally different flow characteristics. I don't think the average guy has a fighting chance of figuring this stuff out since most folks just can't afford to haul a trunk load of carbs to the dyno and sit there for two days flogging carbs. But I don't know of any other way to see the differences. The best Dominator I've ever seen on the dyno is a 80902 right out of the box. If anyone ever asks me for a Dominator recommendation that is what I tell them to buy. 80902 in whatever color you want. Take it out of the box and bolt it on. Not that it is a huge difference from other carbs but a 80902 will usually make 10 to 20 hp more than any older style Dominator. That may or may not be worth it, just depends on what a person is trying to do with their car.
