Re: FYI...hand oils do go through epoxy primer...
[Re: ksat]
#2645724
04/16/19 02:20 PM
04/16/19 02:20 PM
Posts: 5,664 South Dakota
hotairballoonpilot
South Dakota
One thing to remember on anything that is basted then sprayed with epoxy is this. The micro surface profile of the metal after being blasted has lots of peaks and valley's. Most paint manufacturers want a minimum of 2 mills over blasted metal for protection. So the valleys naturally have more than the peaks do. I would guess that that is more your issue than anything else. How many coats were applied? What brand of epoxy?
corey
Contact Me about AMD Prices
[Re: hudsonhornet7x]
#2645729
04/16/19 02:36 PM
04/16/19 02:36 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
Whenever I blast one, I try and epoxy/etch prime asap and I always wear gloves when handling the bare metal. Also need a lower humidity day, otherwise asking for problems.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: Neil]
#2646424
04/18/19 10:54 AM
04/18/19 10:54 AM
Posts: 1,541 USA
hudsonhornet7x
USA
PPG makes a metal wash that can be used on bare steel to help seal the metal. Yes and it is a great product, but be aware that acids ( like the wash primer) and epoxy primers usually do not like each other at all. It is usually one or the other.
[Re: Neil]
#2646505
04/18/19 03:13 PM
04/18/19 03:13 PM
Posts: 28,596 Shopping @ HoBo Fright
340SIX
Doc Flappergas's Evil Twin
PPG makes a metal wash that can be used on bare steel to help seal the metal. This DX579 Wash with Hot Water, Then wipe with Lacquer thinner or Paint Prep Solvent
[Re: 340SIX]
#2648859
04/25/19 01:17 PM
04/25/19 01:17 PM
hotairballoonpilot
South Dakota
PPG makes a metal wash that can be used on bare steel to help seal the metal. This DX579 Wash with Hot Water, Then wipe with Lacquer thinner or Paint Prep Solvent By ALL means DO NOT use ANY etch primers or metal preps on any sandblasted metal. The metal is ALREADY etched with the blasting. You will have issues later on if you do it that way. 25+ years spraying PPG Master Certified.
