Well Darn!!! problem found #2644788
04/13/19 06:18 PM
04/13/19 06:18 PM
W. Kentucky
justinp61 Offline OP
W. Kentucky
Today I was changing the oil in my Dart and after it all drained out I cut a slim strip of a clean rag and pit it on a wire to reach in the drain plug hole and wipe the bottom of the pan. I didn't find anything alarming but what I did find is that the pick tube is loose in the (SB) oil pump. When I put it up for the winter the oil pressure was still 60 psi hot at cruise and 30 psi at idle so I don't think anything is hurt. The engine will have to come out so I can fix it. I'm thinking that I'll fab some sort of tab to one of the main studs to prevent this from happening again, plus I'll check the bearings while the pan is off. I've built several small blocks over the years and never had this issue.
Re: Well Darn!!! [Re: justinp61] #2644800
04/13/19 07:25 PM
04/13/19 07:25 PM
gregsdart Offline
gregsdart  Offline
You may be able to drop the pan by supporting the engine with a 6×4 long enough to span the inner fenderwells, and use tie down straps to hold the motor up so you can drop the k frame enough to get the pan off. I haven't done it with all the stock steering gear still in place, so it might require dropping the drag link and disconecting the steering wheel. This is assuming you have a stock k frame of course😀
Re: Well Darn!!! [Re: gregsdart] #2644808
04/13/19 07:44 PM
04/13/19 07:44 PM
MR_P_BODY Offline
MR_P_BODY  Offline
How deep is the pan.. sounds like a lot of work to drop the pan.. I dont
have to do anything to drop my pan with struts.. pull the pan bolts and
it can fall off
wave
Re: Well Darn!!! [Re: gregsdart] #2644810
04/13/19 07:46 PM
04/13/19 07:46 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I had the same problem a few years ago on my old 360. Lost oil pressure under any acceleration or braking. A friend of mine and i pulled the motor, fixed it, and put it back in about 4-5 hours. Not my idea of fun but we looked at getting the milodon pan off in the car and it was quickly apparent that pulling the engine would be the easiest thing to do.
68 Barracuda Formula S 340
Re: Well Darn!!! [Re: Bad340fish] #2644822
04/13/19 08:35 PM
04/13/19 08:35 PM
W. Kentucky
W. Kentucky
Yep, I have a Milodon pan too. I've looked it over and think pulling it is the best move. Mike if it had a strut front the pan would already be off.
Re: Well Darn!!! [Re: justinp61] #2644828
04/13/19 08:56 PM
04/13/19 08:56 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
This why I always trim the K frame now. Oil pan slides right out.
Doug
Re: Well Darn!!! [Re: dvw] #2644831
04/13/19 09:02 PM
04/13/19 09:02 PM
W. Kentucky
W. Kentucky
Doug
Hind sight is always 20/20. Had I thought about it I would've trimmed and boxed the K member before I painted it 10 years ago. Live and learn I suppose.
Re: Well Darn!!! [Re: dvw] #2644832
04/13/19 09:05 PM
04/13/19 09:05 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
I drop the pan on my SB Duster without pulling the motor, and it's a huge 10-quart monster.
The trick is to turn the crank a little so the counterweight clears the front of the pan as you slide it back.
There's a position where it clears, and once you find it, mark your balancer accordingly.
Re: Well Darn!!! [Re: justinp61] #2644903
04/14/19 02:30 AM
04/14/19 02:30 AM
What year Dart?
I've removed more than one oil pan off of the 1967 and later A bodies with273,318, 340 and probably a 360 C.I.or two with the motor in the car, drop the steering center link, idler arm and passenger side tie rod and slide them out of your way and remove the oil pan bolts up to remove the oil pan up scope
I've also heard bad things about Milidon welded extended oil pick up for their deep center sump pan breaking the welds puke whiney
Re: Well Darn!!! [Re: Cab_Burge] #2644997
04/14/19 11:51 AM
04/14/19 11:51 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Topside, that trick with the crank throws has worked for me for years,
and I mean YEARS, as I am 77!!
Joe
Re: Well Darn!!! [Re: Cab_Burge] #2645241
04/15/19 06:24 AM
04/15/19 06:24 AM
Australia
dodgy Offline
dodgy  Offline
Australia
Also cheek the inside of every brandnew milodon pickup tube as the two i got were rusty inside just past the welded on threaded end, got a replacement and it was rusty aswell, had to submerge it in a molasses bath to eat the rust.
Re: Well Darn!!! [Re: dodgy] #2645823
04/16/19 08:33 PM
04/16/19 08:33 PM
Stoney Creek, Ontario, Canada
76Beeper Offline
76Beeper  Offline
Here's the extended pick-up that comes with the Kevco oil pan.
It has a bracket to support it on a main cap bolt.
Actually Kevco sells a new bolt with a stud portion to fit that bracket and secure it with a nut.
Re: Well Darn!!! problem found [Re: justinp61] #2646940
04/19/19 07:24 PM
04/19/19 07:24 PM
W. Kentucky
W. Kentucky
I finally got around to pulling the pan, thank goodness my Hedman headers come apart in several pieces. The Milodon pick up broke off in the pump about 1/8-3/16" from the end of the tube. Now the problem is getting the broke part out of my pump, I tried a large ease out but I think it made it worse.
Re: Well Darn!!! problem found [Re: justinp61] #2647332
04/20/19 05:47 PM
04/20/19 05:47 PM
W. Kentucky
W. Kentucky
Photos.
Re: Well Darn!!! problem found [Re: justinp61] #2647335
04/20/19 05:57 PM
04/20/19 05:57 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
The Milodon pick up tubes seem to be pretty fragile.
I had a BB one break just about like that while I was installing it.
Whatever they’re using for the threaded area seems to be thinner and more brittle than the OE type of tube.
Re: Well Darn!!! problem found [Re: fast68plymouth] #2647507
04/21/19 10:18 AM
04/21/19 10:18 AM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
I had one break on a 340 at high rpm in that same place
Re: Well Darn!!! problem found [Re: justinp61] #2647522
04/21/19 11:10 AM
04/21/19 11:10 AM
central il.
second 70 Offline
second 70  Offline
central il.
This one broke off in the block on my hemi a year ago. Been in there for years so all I could think of was vibration?
Broke off in the same place as yours.
I used one of the extractors that had a square end on it to remove it. A little different than an easy out.
Re: Well Darn!!! problem found [Re: second 70] #2647734
04/22/19 09:39 AM
04/22/19 09:39 AM
moparx Offline
moparx  Offline
there are tools that act like easy outs that are for extracting pipe nipples, but i haven't seen any smaller than for 3/4" pipe.
one of the main reasons [in my opinion] those pickups break there, is the tube is thinner wall thickness than the factory pickup, and after the thread is cut, it makes the wall thickness that much thinner. add the fact there is [usually] no support for the bottom or the tube itself, and the least vibration starts the cracking effect.
beer
Re: Well Darn!!! problem found [Re: moparx] #2647742
04/22/19 09:58 AM
04/22/19 09:58 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
beer
It doesn't help matters that with tapered pipe thread and the pick-up has to end up in a certain position. Should I try one more turn or not. WELL DO YOU FEEL LUCKY.??? Loose or over-tight.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Well Darn!!! problem found [Re: moparx] #2647744
04/22/19 10:05 AM
04/22/19 10:05 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
I think part of the problem with the threads is most (if not all) threads we see now are cut
instead of the alternative of rolled threads, which are stronger and don't remove any material.
Of course as mentioned, many aftermarket pick-ups can't touch the bottom of the pan
to operate effectively.
The factory big block pick-ups are designed to have a little interference with the pan which
Ma probably figured out a looongg time ago helped add some stability to the connection.
My 2 cents...Joe
