1st gear in drive is rear clutch and over running clutch in use. If it still doesn't move when shifted manually into 1st you can rule out the over running clutch as the problem. Reverse uses the front clutch and rear band so we know they work. You either have a rear clutch failure or a gear train failure. It's not going to be anything electrical.
