1st gear in drive is rear clutch and over running clutch in use. If it still doesn't move when shifted manually into 1st you can rule out the over running clutch as the problem. Reverse uses the front clutch and rear band so we know they work. You either have a rear clutch failure or a gear train failure. It's not going to be anything electrical.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
