factory water temperature sender ohm value ? #2643187
04/09/19 11:39 AM
04/09/19 11:39 AM
moparx Online content OP
moparx  Online Content OP
does anyone know the factory water temperature sender ohm value for a mid 70's big block ? i tried to search, but failed in finding a result.
as usual, TIA ! bow
beer
Re: factory water temperature sender ohm value ? [Re: moparx] #2643195
04/09/19 11:56 AM
04/09/19 11:56 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
See pic
Don't be the exception.
Re: factory water temperature sender ohm value ? [Re: moparx] #2643237
04/09/19 01:35 PM
04/09/19 01:35 PM
I'm under the impression that those senders generate a small amount of current, voltage, not increase or decrease the Ohms shruggy work scope
Re: factory water temperature sender ohm value ? [Re: Cab_Burge] #2643250
04/09/19 02:02 PM
04/09/19 02:02 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Voltage variation is due the ohms variation
Re: factory water temperature sender ohm value ? [Re: NachoRT74] #2643252
04/09/19 02:04 PM
04/09/19 02:04 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
It's a variable resistance similar to a fuel gauge sender.
Re: factory water temperature sender ohm value ? [Re: NachoRT74] #2643469
04/09/19 11:16 PM
04/09/19 11:16 PM
I know the fuel sender is a varistor (variable resistor) but I've been told that both the water temp and oil pressure senders generate current back to the meter, not resistance shruggy confused
I'll have to do some testing on the water temp senders I have in both hot and then cold water using a good VOM using Ohms and then very low DC voltage scope wrench
Re: factory water temperature sender ohm value ? [Re: Cab_Burge] #2643474
04/09/19 11:31 PM
04/09/19 11:31 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
The fuel sender would technically be called a rheostat (variable resistor).
A varistor is a different device where the resistance varies with applied voltage. A lighting arrestor many times is a varistor. A rheostat is a variable resistor with 2 connections and a potentiometer is a variable resistor with 3 connections.
Re: factory water temperature sender ohm value ? [Re: Cab_Burge] #2643541
04/10/19 08:59 AM
04/10/19 08:59 AM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
If I understand it correctly, there is a resistance value of the sender that varies with the temperature (or pressure for oil). The system is set up to supply a small (5 volts) to the circuit. The voltage at the return of the circuit is measured by the gauge. The gauge is indicating how much current made it through the circuit. The higher the resistance, the less current that made it through the loop, the lower the reading on the gauge. The lower the resistance, the more current that makes it to the gauge, and the higher the reading. Note on the photo, the reading at low temperature is highest resistance and vice versa.
Of course, I am a mechanical engineer, and my rudimentary understanding of most electrical stuff is that once you let the smoke out, the device doesn't work.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: factory water temperature sender ohm value ? [Re: RoadRunner] #2643617
04/10/19 11:19 AM
04/10/19 11:19 AM
stuffing the "secret smoke" back into the wire is a pretty tough thing to accomplish ! [i've tried it with not much success biggrin]
the 74/23/10 value i am familiar with for the gas gauge, but i thought the oil and water senders were different ? shruggy i also know the light senders are different than the gauge senders.
the reason i am asking, is i have a bunch of different temperature senders, and the sure "look" like they could be for a chrysler engine, but i don't know how to test them because i don't have the factory sending unit tester tool. so ????????
beer
Re: factory water temperature sender ohm value ? [Re: Supercuda] #2643729
04/10/19 04:07 PM
04/10/19 04:07 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
" Connect one load of C-3826."
From the pic in the second post, is this a typo?
Should it not be connect one lead?
I have mechanical Aptitude.
I can screw up anything.
Re: factory water temperature sender ohm value ? [Re: markz528] #2643730
04/10/19 04:11 PM
04/10/19 04:11 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
And a thermistor varies with heat. Like the ballast or the choke regulating resistor on later Mopars. Or the temperature sender.
https://www.forabodiesonly.com/mopar/threads/engine-temp-sensor-specs.184924
Re: factory water temperature sender ohm value ? [Re: Supercuda] #2643901
04/10/19 11:02 PM
04/10/19 11:02 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
I would not think that a thermistor would be used for a temp sensor in a car. A thermistor is a very non-linear device and I don't believe that would be well suited for this application. I believe a linear device like a RTD would be more suitable for a temp sensor, but I do not know the exact technology used in the temp sensors.
Re: factory water temperature sender ohm value ? [Re: Supercuda] #2643998
04/11/19 11:26 AM
04/11/19 11:26 AM
thanks for the A bodies link. interesting reading.
beer
Re: factory water temperature sender ohm value ? [Re: moparx] #2644189
04/11/19 09:25 PM
04/11/19 09:25 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
https://en.wikipedia.org/wiki/Thermistor
read list of uses for NTC type
Re: factory water temperature sender ohm value ? [Re: Cab_Burge] #2644520
04/12/19 08:24 PM
04/12/19 08:24 PM
Boise
Moparteacher Offline
Boise
It's a NTC Negative Temperature Coefficient resistor. It does not produce voltage. As temperature goes up resistance goes down. It is the second resistor in a series circuit. The first resistor is mounted in the gauge and is fixed. As resistance in the temp sender changes with temperature the current in the circuit changes thus changing the magnetic field in the first resistor (gauge). The magnetic field acts on the metallic needle and moves the needle.
OK, technically it's a parallel circuit. The first branch is fixed and produces a fixed magnetic field that pulls the needle low (cold). The second branch has a fixed (apposing) resistor opposite the the first branch in the gauge and the the variable NTC down-circuit. As temperature rises, resistance lowers and current in the second branch goes up creating a stronger magnetic field and pulling the needle high (hot).
Re: factory water temperature sender ohm value ? [Re: Moparteacher] #2644530
04/12/19 08:52 PM
04/12/19 08:52 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Lets simplify this...
Basically the temp gauge like the fuel gauge, oil pressure are a 5VDC meter.
The water temperature sensor varies its resistance with water temperature variations so that the meter tracks accordingly.
Just my $0.02... wink
Re: factory water temperature sender ohm value ? [Re: Sinitro] #2644675
04/13/19 10:53 AM
04/13/19 10:53 AM
all righty then ! you guys have "learned me" something new. boogie now, if i can just retain it ! i think more and more about trying that "brain medicine in pill form" they sell on late nite TV. work biggrin
so now, using the 74/23/10 chart, if i touch the negative [black] probe [of my digital ohm meter] to the base of the sending unit that is immersed in the coolant, and touch the positive [red] lead to the signal wire end of the sending unit, it should read close to 73 ohms at room temperature, correct ? my main goal in all of this, is to weed out possible generic sending units from factory chrysler sending units.
thanks guys ! you have been very patient with this old geezer !
beer
Re: factory water temperature sender ohm value ? [Re: moparx] #2644680
04/13/19 11:01 AM
04/13/19 11:01 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Yes, you have it.
Re: factory water temperature sender ohm value ? [Re: Supercuda] #2644685
04/13/19 11:04 AM
04/13/19 11:04 AM
up bow boogie
beer
