Re: factory water temperature sender ohm value ?
[Re: Cab_Burge]
#2643250
04/09/19 02:02 PM
04/09/19 02:02 PM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
Voltage variation is due the ohms variation
[Re: NachoRT74]
#2643252
04/09/19 02:04 PM
04/09/19 02:04 PM
Posts: 10,717 North Dakota
6PakBee
North Dakota
It's a variable resistance similar to a fuel gauge sender.
[Re: Cab_Burge]
#2643474
04/09/19 11:31 PM
04/09/19 11:31 PM
Posts: 4,270 Morrow, OH
markz528
Morrow, OH
The fuel sender would technically be called a rheostat (variable resistor). A varistor is a different device where the resistance varies with applied voltage. A lighting arrestor many times is a varistor. A rheostat is a variable resistor with 2 connections and a potentiometer is a variable resistor with 3 connections.
[Re: Cab_Burge]
#2643541
04/10/19 08:59 AM
04/10/19 08:59 AM
Posts: 5,138 East Aurora (Buffalo) NY
RoadRunner
If I understand it correctly, there is a resistance value of the sender that varies with the temperature (or pressure for oil). The system is set up to supply a small (5 volts) to the circuit. The voltage at the return of the circuit is measured by the gauge. The gauge is indicating how much current made it through the circuit. The higher the resistance, the less current that made it through the loop, the lower the reading on the gauge. The lower the resistance, the more current that makes it to the gauge, and the higher the reading. Note on the photo, the reading at low temperature is highest resistance and vice versa.
Of course, I am a mechanical engineer, and my rudimentary understanding of most electrical stuff is that once you let the smoke out, the device doesn't work.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
[Re: RoadRunner]
#2643617
04/10/19 11:19 AM
04/10/19 11:19 AM
Posts: 19,406 north of coder
moparx
stuffing the "secret smoke" back into the wire is a pretty tough thing to accomplish ! [i've tried it with not much success ] the 74/23/10 value i am familiar with for the gas gauge, but i thought the oil and water senders were different ? i also know the light senders are different than the gauge senders. the reason i am asking, is i have a bunch of different temperature senders, and the sure "look" like they could be for a chrysler engine, but i don't know how to test them because i don't have the factory sending unit tester tool. so ????????
[Re: Supercuda]
#2643729
04/10/19 04:07 PM
04/10/19 04:07 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
" Connect one load of C-3826." From the pic in the second post, is this a typo? Should it not be connect one lead?
I have mechanical Aptitude. I can screw up anything.
[Re: markz528]
#2643730
04/10/19 04:11 PM
04/10/19 04:11 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
The fuel sender would technically be called a rheostat (variable resistor). A varistor is a different device where the resistance varies with applied voltage. A lighting arrestor many times is a varistor. A rheostat is a variable resistor with 2 connections and a potentiometer is a variable resistor with 3 connections. And a thermistor varies with heat. Like the ballast or the choke regulating resistor on later Mopars. Or the temperature sender. https://www.forabodiesonly.com/mopar/threads/engine-temp-sensor-specs.184924
[Re: Supercuda]
#2643901
04/10/19 11:02 PM
04/10/19 11:02 PM
markz528
Morrow, OH
The fuel sender would technically be called a rheostat (variable resistor). A varistor is a different device where the resistance varies with applied voltage. A lighting arrestor many times is a varistor. A rheostat is a variable resistor with 2 connections and a potentiometer is a variable resistor with 3 connections. And a thermistor varies with heat. Like the ballast or the choke regulating resistor on later Mopars. Or the temperature sender. https://www.forabodiesonly.com/mopar/threads/engine-temp-sensor-specs.184924 I would not think that a thermistor would be used for a temp sensor in a car. A thermistor is a very non-linear device and I don't believe that would be well suited for this application. I believe a linear device like a RTD would be more suitable for a temp sensor, but I do not know the exact technology used in the temp sensors.
[Re: Cab_Burge]
#2644520
04/12/19 08:24 PM
04/12/19 08:24 PM
Posts: 609 Boise
Moparteacher
Boise
It's a NTC Negative Temperature Coefficient resistor. It does not produce voltage. As temperature goes up resistance goes down. It is the second resistor in a series circuit. The first resistor is mounted in the gauge and is fixed. As resistance in the temp sender changes with temperature the current in the circuit changes thus changing the magnetic field in the first resistor (gauge). The magnetic field acts on the metallic needle and moves the needle.
OK, technically it's a parallel circuit. The first branch is fixed and produces a fixed magnetic field that pulls the needle low (cold). The second branch has a fixed (apposing) resistor opposite the the first branch in the gauge and the the variable NTC down-circuit. As temperature rises, resistance lowers and current in the second branch goes up creating a stronger magnetic field and pulling the needle high (hot).
[Re: Moparteacher]
#2644530
04/12/19 08:52 PM
04/12/19 08:52 PM
Posts: 5,439 So Cal
Sinitro
So Cal
Lets simplify this... Basically the temp gauge like the fuel gauge, oil pressure are a 5VDC meter. The water temperature sensor varies its resistance with water temperature variations so that the meter tracks accordingly. Just my $0.02...
