Re: Street stroker quench ??
[Re: Stanton]
#2644829
04/13/19 08:57 PM
04/13/19 08:57 PM
Posts: 43,286 Bend,OR USA
Cab_Burge
Wondering if I can stack three stock-style .019 steel gaskets ?? Are you feeling lucky? I wouldn't do that
[Re: Cab_Burge]
#2644946
04/14/19 09:36 AM
04/14/19 09:36 AM
Posts: 8,908 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Originally Posted by Stanton Wondering if I can stack three stock-style .019 steel gaskets ??
Are you feeling lucky? work I wouldn't do that tsk
I was just a thought. So what would cause contact with the head anyway? I have .035 quench. Let's say for the hell of it the piston rocks .010. Where's the other .025 go in order for the piston to contact the head ??
[Re: Stanton]
#2645036
04/14/19 01:37 PM
04/14/19 01:37 PM
Cab_Burge
My old pump gas stroker motor was at zero deck height with dished pistons using having .035 piston the head clearances that would touch the heads with the edges of the pistons on both sides of those pistons They didn't touch with .042 clearances Back then I wasn't rocking the pistons to check the pistons edge deck heights I do now
