E body fuel sending unit #2642406
04/07/19 07:16 PM
04/07/19 07:16 PM
STL
cdstl Offline OP
cdstl  Offline OP
STL
I know this comes up, but I've never paid attention since I haven't need one.
The question is who do you guys like for a fuel sending unit for an E body?
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: E body fuel sending unit [Re: cdstl] #2642614
04/08/19 08:52 AM
04/08/19 08:52 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
this is an ongoing saga ive NEVER found one thats even close to right.now and then someone gets lucky ,but its rare.someone prove me wrong PLEASE!!!
Re: E body fuel sending unit [Re: bonefish] #2642701
04/08/19 12:08 PM
04/08/19 12:08 PM
Colorado front range
BcudaChris Offline
BcudaChris  Offline
Vans Auto got me one that worked 2nd time around. They'll test the resistance prior to shipping. You'll probably have to tweak the arm to get it to read properly.
Basically, hit or miss and all junk is my experience with two vendors and 5 pickups shipped. Vendors don't even want them back and 1st vendor (classic industries) offered up a refund 1st before offering to replace.
Re: E body fuel sending unit [Re: BcudaChris] #2642764
04/08/19 02:25 PM
04/08/19 02:25 PM
Agreed, they are the worst of the worst. You might call a yard & see if you can locate a good used one.
Re: E body fuel sending unit [Re: RapidRobert] #2642818
04/08/19 04:14 PM
04/08/19 04:14 PM
North Carolina
469runner Offline
469runner  Offline
North Carolina
Knowing how bad the replacement sending units are, I sent my original Cuda one to this company to rebuild. Works perfectly. http://tristarrradiator.com/Classic%20%20Vintage%20Page/Classic%20%20Vintage%20Page.html
Re: E body fuel sending unit [Re: 469runner] #2642838
04/08/19 04:42 PM
04/08/19 04:42 PM
BcudaChris Offline
BcudaChris  Offline
Dang! Wish I'd thought to look for a re builder before I got into the repop nightmare. Mine works fine, just my recipe called for a 3/8" pickup with a return instead of a 5/16".
Re: E body fuel sending unit [Re: 469runner] #2642845
04/08/19 04:49 PM
04/08/19 04:49 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
Thanks for sharing this. The last place I had a bookmark for that would rebuild them got out of that business.
FYI...the link as is does not work for me. Crop it to tristarradiator.com and it goes through.
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: E body fuel sending unit [Re: cdstl] #2643025
04/08/19 11:04 PM
04/08/19 11:04 PM
STL
cdstl Offline OP
cdstl  Offline OP
STL
My gauge shows just over half with the tank full and it takes about a full minute to get there.
Does it do any good to bend the float up?
Re: E body fuel sending unit [Re: 469runner] #2643227
04/09/19 01:13 PM
04/09/19 01:13 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Cool, think they could convert a 5/16 to 3/8?
Re: E body fuel sending unit [Re: TC@HP2] #2643230
04/09/19 01:15 PM
04/09/19 01:15 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Link right on the front page modified pickups
Don't be the exception.
Re: E body fuel sending unit [Re: Supercuda] #2643240
04/09/19 01:41 PM
04/09/19 01:41 PM
Brownstown, PA
FJR doc Offline
FJR doc  Offline
Brownstown, PA
A-body repop fuel sending units aren't any better. I was lucky to find a NOS one at Carlisle. If NOS isn't an option, I would send your original for a rebuild.
Follow my Duster 340 restoration progress on FABO http://www.forabodiesonly.com/mopar/showthread.php?t=225784
Kevin
