Steering column dis-assembly #2642273
04/07/19 12:47 PM
04/07/19 12:47 PM
Pikes Peak Country
TC@HP2 Offline OP
TC@HP2  Offline OP
Pikes Peak Country
Rebuilding my ‘74 Challenger steering column. So far so good with basic tear down but I’ve run into a hiccup. It’s a column shift auto. How do I get the shift tube off the steering shaft?
Re: Steering column dis-assembly [Re: TC@HP2] #2642280
04/07/19 01:10 PM
04/07/19 01:10 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
EDIT,
remove the shift lever to access the counter sunk set screw. Just loosen it a tad and the collar should slide right off the tube
Re: Steering column dis-assembly [Re: gtx6970] #2642288
04/07/19 01:26 PM
04/07/19 01:26 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
No experience with one that new here either.
If I remember right (on a '70) the column gear shift handle has to be removed for access to the set screw.
Re: Steering column dis-assembly [Re: Alaskan_TA] #2642441
04/07/19 08:38 PM
04/07/19 08:38 PM
Pikes Peak Country
TC@HP2 Offline OP
TC@HP2  Offline OP
Pikes Peak Country
Already removed shift lever and set screw. Collar was pressed on the shift tube. Took some taping with a mallet to get collar off the tube. Now, how does the tube come off the steering shaft or vice-a-versa? At present, it does not slide off. There is an obvious seal at one end, but it has no apparent tabs. A small diameter wire spring presses into this seal and seats against a large diameter wire snap ring looking device. There is no apparent grooves for this snap ring, but at around .180 in diameter, it’s not going to be easily spread . It will spin on the shaft, but won't spread open without a pretty monster set of pliers. The upper tube is flopping around on the shaft.
