Viscous Fan Clutch #2640016
04/02/19 05:06 AM
04/02/19 05:06 AM
upstate western ny
sogtx Offline OP
sogtx  Offline OP
upstate western ny
So im a fan blade away from firing engine up
I bought viscous fan kit 3-4 years ago
Nice blade , but not so sure I received the correcf
clutch .
The ones ive seen advertised have a
spring on front of the clutch
I received a part number 17051613
No spring on front
What kinda clutch did I receive
Ive googled the part number backwards and
forwards ..
Am I going to end up doin this twice ?
When i look at Manicinis site the clutch looks
similar but their kit has 7 blades .
This is image of clutch I received
Obviously is non thermostatic ..
Re: Viscous Fan Clutch [Re: sogtx] #2640017
04/02/19 05:08 AM
04/02/19 05:08 AM
upstate western ny
sogtx Offline OP
sogtx  Offline OP
upstate western ny
This is clutch ive seen as shipped on
Orig viscous fan packages
Re: Viscous Fan Clutch [Re: sogtx] #2640019
04/02/19 06:32 AM
04/02/19 06:32 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
The type of clutch you need depends on your application. What is your combo? Car, eng, a/c, or no ect.
Re: Viscous Fan Clutch [Re: 71birdJ68] #2640042
04/02/19 08:19 AM
04/02/19 08:19 AM
Canuckville
68Cbarge Offline
68Cbarge  Offline
Canuckville
popcorn
I pt a clutch fan on my 73 318 wagon (3 speed manual,no a/c no powr steering) and it ran hotter than the basic 8 blade.
Watching this with interest..
popcorn
'68 Newport Custom Barge on a Budget!! BOAB
1973 Satellite WAGON! 318- 3 on the tree!!
2008 Chrysler 300c HEMI!
Re: Viscous Fan Clutch [Re: sogtx] #2640079
04/02/19 09:03 AM
04/02/19 09:03 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Original fan for most B-body's would be 18 1/2" seven blade ,either thermostatic or torque depending on application. Most HP applications use 2806070 clutch & 18 1/2" 2863216 blade.
Re: Viscous Fan Clutch [Re: 62maxwgn] #2640107
04/02/19 10:01 AM
04/02/19 10:01 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Interestingly, in my last MP catalog, for part number P4120758, at the end of the description it says “not for street use”.
My understanding is this was sold as a “horsepower saving” package, not factory replacement type package.
Re: Viscous Fan Clutch [Re: fast68plymouth] #2640253
04/02/19 03:18 PM
04/02/19 03:18 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Yes, correct. If memory serves (it's been 6 years), original application for the clutch was
a 6 cylinder vehicle, and it is designed to slip and save power.
The 5 blade fan was used on v8 M bodies, and is fine for most apps.
If that is all right, my next step would be to check the 4-series OE part number above to see if it supersedes to
the new OE number you were shipped. I'm thinking it most likely does not
Rich H.
Esse Quam Videri
Re: Viscous Fan Clutch [Re: ZIPPY] #2640351
04/02/19 07:18 PM
04/02/19 07:18 PM
IN
ahy Offline
ahy  Offline
IN
Two sources for the thermostatic clutch. Bouchillon... but you have to ask for it. Last I looked they advertise the non thermal version like Mancini.
Or NAPA. You can likely get the right thermal clutch there.
I prefer the thermal... less fan speed, power loss and noise when things are cool.
Re: Viscous Fan Clutch [Re: 71birdJ68] #2640371
04/02/19 08:14 PM
04/02/19 08:14 PM
upstate western ny
sogtx Offline OP
sogtx  Offline OP
upstate western ny
But Original question was WHAT DID I GET ? LOL
looks like an 070 non thermal repop ?
ill open up pandoras box with some you
i dont wanna hear i need alum rad , electric fans , nada.
every car I have has a thermal clutch
this particular one 520 stroker with a 190 stat and a 3 core 054 rad With a SHROUD
I have a stock 6 pack 18 1 /2 blade and a 5 blades viscous ..
Ill give the 5 blade a try
The last two drivers have had the 5 blade for past 15 years
Re: Viscous Fan Clutch [Re: sogtx] #2640521
04/03/19 09:04 AM
04/03/19 09:04 AM
Stuttgart, Arkansas
rickseeman Online content
rickseeman  Online Content
Stuttgart, Arkansas
You got a Chinese fan clutch
2011 Drag Pak Challenger
