07 truck into a 06 car? #2639120
03/31/19 10:05 AM
03/31/19 10:05 AM
British Columbia
chrisf Offline OP
chrisf  Offline OP
British Columbia
07 truck hemi into a 06 300. long block swap. anything to keep in mind? obviously pan and accessories but anything else? i am thinking of building a stroker with the 07 motor.
Re: 07 truck into a 06 car? [Re: chrisf] #2639447
04/01/19 12:07 AM
04/01/19 12:07 AM
Northern California
B5 Classic Offline
B5 Classic  Offline
Northern California
Just swap your intake manifold, oil pan, oil pick up, front cover and accessories with what's on the truck engine and install it. Pretty simple swap. Actually, I'd swap all known good sensors too. Also, count the grooves in the front dampers to make sure they're the same. Although, since you'll have them both off to change the front covers, I think I'd use the damper from the car engine.
Re: 07 truck into a 06 car? [Re: B5 Classic] #2639561
04/01/19 10:21 AM
04/01/19 10:21 AM
British Columbia
chrisf Offline OP
chrisf  Offline OP
British Columbia
thanks B5. easy swap then.
Re: 07 truck into a 06 car? [Re: chrisf] #2639628
04/01/19 12:25 PM
04/01/19 12:25 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Is the 07 truck motor MDS? If its from a 1500 it will be, from a 2500/3500 it won't. It has to be an MDS motor or get a tune to switch the MDS off
Re: 07 truck into a 06 car? [Re: B5 Classic] #2640187
04/02/19 12:50 PM
04/02/19 12:50 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
Spacing from the front of the block outward is different between car and truck hemis, will need to swap the balancer with the rest of it.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
