Re: 07 truck into a 06 car?
[Re: chrisf]
#2639447
04/01/19 12:07 AM
04/01/19 12:07 AM
Posts: 33 Northern California
B5 Classic
Northern California
Just swap your intake manifold, oil pan, oil pick up, front cover and accessories with what's on the truck engine and install it. Pretty simple swap. Actually, I'd swap all known good sensors too. Also, count the grooves in the front dampers to make sure they're the same. Although, since you'll have them both off to change the front covers, I think I'd use the damper from the car engine.
[Re: B5 Classic]
#2640187
04/02/19 12:50 PM
04/02/19 12:50 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
Just swap your intake manifold, oil pan, oil pick up, front cover and accessories with what's on the truck engine and install it. Pretty simple swap. Actually, I'd swap all known good sensors too. Also, count the grooves in the front dampers to make sure they're the same. Although, since you'll have them both off to change the front covers, I think I'd use the damper from the car engine. Spacing from the front of the block outward is different between car and truck hemis, will need to swap the balancer with the rest of it.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
