Ammeter to voltmeter #2638974
03/30/19 08:55 PM
03/30/19 08:55 PM
STL
cdstl Offline OP
cdstl  Offline OP
STL
I just got my Cuda's standard dash back from Instrument Specialties. Looks good. I had them convert the ammeter to a voltmeter.
So, now how do I hook it up?
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: Ammeter to voltmeter [Re: cdstl] #2638997
03/30/19 10:06 PM
03/30/19 10:06 PM
neg to ground. positive to switched 12V, not sure where the best pickup point would be, maybe a switched circuit in the fuse box. EDIT or maybe the blue wire ign1 circuit as that is what the "system" is seeing at any point in time.
Re: Ammeter to voltmeter [Re: cdstl] #2639036
03/30/19 11:59 PM
03/30/19 11:59 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Now you have a Voltmeter: Great for monitoring Alt./V-reg operation. But Now how do you monitor battery state while operating car: Charged-Charging-DisCharging?
Re: Ammeter to voltmeter [Re: PhillyRag] #2639037
03/31/19 12:27 AM
03/31/19 12:27 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Voltmeter gets hooked parallel and ammeter in series. Ron
Re: Ammeter to voltmeter [Re: PhillyRag] #2639053
03/31/19 02:57 AM
03/31/19 02:57 AM
IN
ahy Offline
ahy  Offline
IN
If the voltmeter is up it is charging. 13.5-14.5 volts is good or you can tell visually with some experience if no numbers (like mine). If voltage is down it is not. I spotted a failing alternator - no charge - by occasional unusual fluctuations in the voltage.
I hooked mine to the 12 volt feed used to power the instrument panel... it is switched and works fine.
Re: Ammeter to voltmeter [Re: PhillyRag] #2639077
03/31/19 08:21 AM
03/31/19 08:21 AM
STL
cdstl Offline OP
cdstl  Offline OP
STL
I also eliminated a fire hazard.
Gonna post a picture soon. I was gonna give IS a call, but it's the weekend. Probably won't be able to get to it until next weekend anyway.
Re: Ammeter to voltmeter [Re: cdstl] #2639081
03/31/19 08:27 AM
03/31/19 08:27 AM
STL
cdstl Offline OP
cdstl  Offline OP
STL
Here’s what I have now.
Re: Ammeter to voltmeter [Re: ahy] #2639466
04/01/19 02:14 AM
04/01/19 02:14 AM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
While monitoring voltage is helpful; it's still only an Indirect means of monitoring state-of-battery.
With a "healthy" battery & an alt. able to handle any system loads; the ammeter typically only sees
a moderate amp load for a relatively short period: (minor recharge after a start)..
Re: Ammeter to voltmeter [Re: cdstl] #2639572
04/01/19 10:47 AM
04/01/19 10:47 AM
AndyF Offline
AndyF  Offline
You just need to attach 12 volts and ground to hook up a voltmeter.
