2000 Ram - ABS & BRAKE lights on ... #263883
03/23/09 09:17 PM
03/23/09 09:17 PM
State of Corruption
camdog440 Offline OP
State of Corruption
The speedo is also wacko.
Any suggestions? Thanks.
Re: 2000 Ram - ABS & BRAKE lights on ... [Re: camdog440] #263884
03/23/09 10:18 PM
03/23/09 10:18 PM
Carlisle, AR.
mdwyer Offline
mdwyer  Offline
Carlisle, AR.
abd sensor in / on top of the rearend. been there many times.
1970 Challenger T/A
1970 Roadrunner RM21 Vcode
1971 Gtx
1971 Satellite
1971 Charger 500 GB5 383 A54 car
1972 Satellite
1997 Dodge 1500 hunting rig
2014 Ram 2500 Mega Cab
Re: 2000 Ram - ABS & BRAKE lights on ... [Re: mdwyer] #263885
03/23/09 11:27 PM
03/23/09 11:27 PM
State of Corruption
State of Corruption
Thanks. That's what I was thinking too. A mechanic buddy is leaning towards a speed sensor in the trans... that has gone out before and it seems like the truck just didn't know when to shift.
This one acts much different. Everything appears to be working ok... just the idiot lights for ABS and brakes... the speedo doesn't work until above about 20mph.
Re: 2000 Ram - ABS & BRAKE lights on ... [Re: camdog440] #263886
03/24/09 02:00 AM
03/24/09 02:00 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
Mine was the one on top of the rear end.....
It wasnt pretty....
Re: 2000 Ram - ABS & BRAKE lights on ... [Re: sthemi] #263887
03/24/09 09:25 AM
03/24/09 09:25 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
It wasnt pretty....
Thats alot of iron , what does the internals look like ?
Re: 2000 Ram - ABS & BRAKE lights on ... [Re: JohnRR] #263888
03/24/09 10:50 PM
03/24/09 10:50 PM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
The spring washer in the Sure Grip shattered and apparently hit the sensor and one tooth on the tone ring..
I pulled it apart right away, cleaned everything and put a new sensor in about 10k miles ago..so far Sure grip is toast tho..
Here is what was left of the washer...
Re: 2000 Ram - ABS & BRAKE lights on ... [Re: camdog440] #263889
05/08/09 02:23 PM
05/08/09 02:23 PM
Macomb, MI
Giggy Offline
Giggy  Offline
Macomb, MI
Thanks to you my troubles only took a few minutes to repair. I had the exact same symptoms on my 99 Ram and it turned out to be the speed sensor!
I like easy...
