131 tooth flywheel? #2635951
03/23/19 02:42 PM
03/23/19 02:42 PM
Pa.
3
340cpe Offline OP
340cpe  Offline OP
Pa.
Checking out a couple of flywheels that I have and one has a 131 teeth. Counted several times and believe it or not still comes up 131! LOL All the others I have are 130. What gives? Has any one else ever run across this before? It is for a 72-74 era 360. Any and all input appreciated Thanks!
Re: 131 tooth flywheel? [Re: 340cpe] #2636442
03/24/19 01:50 PM
03/24/19 01:50 PM
Pa.
3
340cpe Offline OP
340cpe  Offline OP
Pa.
Well I was hoping to get some type of input. I do not think it will affect starter engagement but was hoping some one else had run across this before I put the flywheel in the car. Now I did see an aftermarket one for sale with 131 teeth listed in the description. Summit or Jegs I believe. My concern is it working correctly and not tearing out starter drives. Thanks
Re: 131 tooth flywheel? [Re: 340cpe] #2636454
03/24/19 02:15 PM
03/24/19 02:15 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Never heard of 131, only 130.
Depends I guess on whether you count teeth or the valley between.
Re: 131 tooth flywheel? [Re: 340cpe] #2636532
03/24/19 04:55 PM
03/24/19 04:55 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The 131-tooth flywheel is used on Dodge 1984-87 L6 3.7l, V6 3.9l.
Re: 131 tooth flywheel? [Re: John_Kunkel] #2636676
03/24/19 10:08 PM
03/24/19 10:08 PM
Pa.
3
340cpe Offline OP
340cpe  Offline OP
Pa.
Well topside I never did either, that is why I posted here. As many times as I count it comes up 131. John thanks for your input but it does have the proper flywheel casting number of 2264598. It is properly drilled for a 360. So the question still remains. Thanks Again everyone
Re: 131 tooth flywheel? [Re: 340cpe] #2636933
03/25/19 12:10 PM
03/25/19 12:10 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The ring gear is separate from the flywheel casting and the 598 casting was used from '62 up past '00.
Re: 131 tooth flywheel? [Re: John_Kunkel] #2637008
03/25/19 03:32 PM
03/25/19 03:32 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Used from '62 past '00? That's a handy tidbit to keep in mind.
Re: 131 tooth flywheel? [Re: John_Kunkel] #2637022
03/25/19 04:08 PM
03/25/19 04:08 PM
Pa.
3
340cpe Offline OP
340cpe  Offline OP
Pa.
Yes John I know the ring gear is separate from the flywheel, I know that casting went up into the 80’s but was unaware of it going into the 00’s. If it was for one of those six cylinders mentioned, were they externally balanced engines? This flywheel is drilled out for what appears to be a 360, three larger holes on the engine side of the flywheel. I have know idea how to post a picture of it or I would.
Re: 131 tooth flywheel? [Re: 340cpe] #2637593
03/27/19 08:17 AM
03/27/19 08:17 AM
New Jersey, USA
Y
yella71 Offline
yella71  Offline
Y
New Jersey, USA
Your not going crazy...I have one also Its all good It wont hurt anything. When I posted here I got the same non response.
71 challenger convertable, 64 sport fury 383 ci with factory air 99 sebring convertable 89 CTD pup
Re: 131 tooth flywheel? [Re: 340cpe] #2637601
03/27/19 08:44 AM
03/27/19 08:44 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I just went on both the Summit and Jegs website and all they list is 130 tooth and 143 tooth, no 131 tooth. But I did find the earlier post. Very interesting.
131 tooth ring gear
Re: 131 tooth flywheel? [Re: 6PakBee] #2637822
03/27/19 06:33 PM
03/27/19 06:33 PM
Pa.
3
340cpe Offline OP
340cpe  Offline OP
Pa.
Sorry about using Jegs or Summit names I should have just used aftermarket. I did find it on the internet and it was not an OEM part.
Re: 131 tooth flywheel? [Re: 340cpe] #2637842
03/27/19 07:17 PM
03/27/19 07:17 PM
Minn
SportF Offline
SportF  Offline
Minn
If you count peaks or valleys, it will come up the same.
Re: 131 tooth flywheel? [Re: 6PakBee] #2638039
03/28/19 11:33 AM
03/28/19 11:33 AM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Originally Posted by 6PakBee
[quote=340cpe] I just went on both the Summit and Jegs website and all they list is 130 tooth and 143 tooth, no 131 tooth.
https://www.summitracing.com/parts/atp-za510/overview/
Re: 131 tooth flywheel? [Re: John_Kunkel] #2638082
03/28/19 01:03 PM
03/28/19 01:03 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Hmm. Guess I should have looked for ring gears rather than flywheels. Ah well, live and learn.
Re: 131 tooth flywheel? [Re: 6PakBee] #2638260
03/28/19 09:35 PM
03/28/19 09:35 PM
Pa.
3
340cpe Offline OP
340cpe  Offline OP
Pa.
Thanks 6PakbeeI knew that I saw it. I was really beginning to think that I was cracking up.
Re: 131 tooth flywheel? [Re: 340cpe] #2638748
03/30/19 09:58 AM
03/30/19 09:58 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Give John the credit, he was the sleuth that nosed this out!!!
Re: 131 tooth flywheel? [Re: 6PakBee] #2638906
03/30/19 04:59 PM
03/30/19 04:59 PM
Pa.
3
340cpe Offline OP
340cpe  Offline OP
Pa.
Thanks I initially did give it to him. I hate posting anything like this because it is away from the norm, right away people think your nuts. Thanks
