What piston stop for a big block? #2636499
03/24/19 04:00 PM
03/24/19 04:00 PM
IL
furious70 Offline OP
IL
What's the best one for an oem head, 9:1 engine?
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: What piston stop for a big block? [Re: furious70] #2636568
03/24/19 06:33 PM
03/24/19 06:33 PM
I made my own on the first one, I knock all the center porcylen and center electrode out of the spark plug and inserted a long 5/16( I think that was the size) bolt with a nut on the cylinder side to lock and hold the bolt into plug body and used it as my first piston stop with the head on.
You can buy them from most any tool truck, they are usually brass or bronze mix also which is good up scope
one of the ones I've bought had a small hole in the center to relive the pressure when moving the piston up towards TDC, I think it whistle also confused
Re: What piston stop for a big block? [Re: Cab_Burge] #2636632
03/24/19 08:48 PM
03/24/19 08:48 PM
Yes get one with the hole in the center.
Re: What piston stop for a big block? [Re: RapidRobert] #2636661
03/24/19 09:38 PM
03/24/19 09:38 PM
IL
IL
I see 14mm and 18mm ones listed but no sae?
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: What piston stop for a big block? [Re: furious70] #2636712
03/24/19 11:00 PM
03/24/19 11:00 PM
What motor are you wanting the SAE one for? What size and thread count do you want?
All the American made car I know of use either a 18MM or a 14MM thread spark plug shruggy
Re: What piston stop for a big block? [Re: Cab_Burge] #2636767
03/25/19 06:45 AM
03/25/19 06:45 AM
IL
IL
BB Mopar.
A lot of the ones I saw listed on Amazon said small gas engines and chain saws so wasn't sure if I'm missing something.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: What piston stop for a big block? [Re: furious70] #2636930
03/25/19 12:09 PM
03/25/19 12:09 PM
14MM
Re: What piston stop for a big block? [Re: furious70] #2636944
03/25/19 12:28 PM
03/25/19 12:28 PM
AndyF Online content
AndyF  Online Content
Spark plugs went metric back around 1930.
Re: What piston stop for a big block? [Re: AndyF] #2636951
03/25/19 12:54 PM
03/25/19 12:54 PM
westerly, ri. usa
440lebaron Online content
440lebaron  Online Content
westerly, ri. usa
as I recall spark plugs were invented overseas in England that's why they are metric??
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: What piston stop for a big block? [Re: AndyF] #2636979
03/25/19 01:55 PM
03/25/19 01:55 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Harley plugs 18mm: 1909
Boffin Emeritus
Re: What piston stop for a big block? [Re: polyspheric] #2636987
03/25/19 02:16 PM
03/25/19 02:16 PM
All the flathead Ford motors I've seen including the 1923 Model T 4 cylinders had 18 MM plugs, maybe some of the earlier cars ones had bigger ones shruggy
Re: What piston stop for a big block? [Re: 440lebaron] #2636998
03/25/19 03:09 PM
03/25/19 03:09 PM
Not sure where they were invented but Albert Champion was a French guy who had a lot of early commercial success making plugs. I think he went on to be the founder of AC Delco also. Some early Fords use pipe threads for plugs but gradually all the popular stuff moved to metric.
Re: What piston stop for a big block? [Re: 440lebaron] #2637003
03/25/19 03:21 PM
03/25/19 03:21 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Of course....... I don’t think England was on board with the metric system “back in the day”.
Re: What piston stop for a big block? [Re: fast68plymouth] #2637113
03/25/19 08:13 PM
03/25/19 08:13 PM
You are correct on that up Them dang English and their English standards rant
That is not to say we Americans have never done that type of thing to go against the worlds standards whistling
Re: What piston stop for a big block? [Re: fast68plymouth] #2637242
03/26/19 08:09 AM
03/26/19 08:09 AM
London, England
Gavin Offline
Gavin  Offline
London, England
Hey ...we still aren't eek
Actually, we're kind of schizophrenic - still universally use miles and mph, milk sold in pints (let's not go there...), sometimes use lbs weight....but at school even oldies like me did all my maths, and Engineering degrees in metric, and pretty much everything else is metric too. I'm just about used to deg C in the weather forecast....but I speak deg F too grin
