Challenger shaker pix needed
#2636579
03/24/19 06:50 PM
03/24/19 06:50 PM
Posts: 740 Anderson, IN
1969RR
Anderson, IN
I'm converting my '70 Challenger RT from the stock RT hood to a shaker set-up. I've purchased the complete shaker set-up from Shakerhood.com, bubble, base plate, etc.....It came with no instructions. Now I do know how most of it goes together, but there were no instructions or patterns to follow to drill the mounting, drain holes, etc in the bubble. I've looked in the factory manual, not much help. I've got a 440RB with single, Super Sniper efi set-up. If someone could post up some pix of the bubble mounting holes, base plate install, etc I would really appreciate it. Also, some pix of the hood center "peak" to the shaker ring match-up. Looks like my new AMD hood gonna need some tweeking to make that line up! Thanks in advance for info and help!
Re: Challenger shaker pix needed
[Re: 1969RR]
#2637336
03/26/19 12:17 PM
03/26/19 12:17 PM
Posts: 18,157 Mass
DAYCLONA
Mass
I should have said the shaker bubble didn't have any holes pre-drilled. I've seen some pictures of other's bubble, and it appears some of the holes are chamfered. My bubble is just flat around the perimeter. Thanks for the reply! Jeff
Just a suggestion as I've done a number of Shaker set ups over the years, ditch the Shakerhood.com/Snobar Shaker bubble and invest in a bubble from Tommy the Chryco (former Gene Gregory units) you'll be glad you did... Mike
[Re: DAYCLONA]
#2637459
03/26/19 07:10 PM
03/26/19 07:10 PM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
Just a suggestion as I've done a number of Shaker set ups over the years, ditch the Shakerhood.com/Snobar Shaker bubble and invest in a bubble from Tommy the Chryco (former Gene Gregory units) you'll be glad you did... Mike ABSOLUTELY! Get one from Tommy or find a real one.
[Re: 71vert340]
#2637763
03/27/19 03:04 PM
03/27/19 03:04 PM
Posts: 4,564 Motor City
6PKRTSE
Motor City
Obviously, no one offers one for a tunnel ram with dual Dominator 4500 carbs so I am making my own with a drop base, leghtened the hood opening and bubble as well as making the bubble taller. Will seal to bottom of hood and stay on engine when done just like factory.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 71vert340]
#2638121
03/28/19 03:03 PM
03/28/19 03:03 PM
Posts: 425 Eastern Ontario
shaker340
Eastern Ontario
71vert340, what upper rad hose are you using there?
Mike
2008 Challenger SRT8 1940 Chrysler Royal coupe
[Re: 6PKRTSE]
#2638133
03/28/19 03:29 PM
03/28/19 03:29 PM
Posts: 5,106 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
6pkrtse to run Doms on a tunnel ram on a Challenger the carbs will likely not fit at the back of the hole and the carbs are to high out of the hole. My Challenger Shaker hood would not do this. Used a flat hood and cut it back a couple of inches toward the window. So if you cut the hole in the hood you will have to fabricate most everything. There is a 1970 Cuda on the drag strip that has a hemi with twin turbos and a made up hood and scoop and it looks pretty nice for a hand made hood. Maybe someone can find a picture of the Cuda and post it for you.
Like many have said and I will extend this that Tommy Chryco sells a pretty nice bubble that fits without any modification. The stuff Chryco sells under the bubble has been changed to duplicate most of what was wrong with it when he took over the company and what he bought from the company was pretty good already. It was very little things he changed to duplicate what Chrysler (Fram Built). Now I would try to sell off the scoop and buy Toms. Instructions are available from one or two person but if you do not have something similar to what Chrysler sold then the instructions might not work for you or cause you more trouble. When the bubble sits on the adaptor ring is messes all together and the bolt holes that would go through the bubble in to the ring would all line up for easy bolting.
1971 HEMI E BODY REGISTRY
[Re: hemicar1971]
#2638496
03/29/19 02:28 PM
03/29/19 02:28 PM
6PKRTSE
Motor City
Like many have said and I will extend this that Tommy Chryco sells a pretty nice bubble that fits without any modification. The stuff Chryco sells under the bubble has been changed to duplicate most of what was wrong with it when he took over the company and what he bought from the company was pretty good already. It was very little things he changed to duplicate what Chrysler (Fram Built). Now I would try to sell off the scoop and buy Toms. Instructions are available from one or two person but if you do not have something similar to what Chrysler sold then the instructions might not work for you or cause you more trouble. When the bubble sits on the adaptor ring is messes all together and the bolt holes that would go through the bubble in to the ring would all line up for easy bolting. Yes, I have stretched the hood opening 3" towards the rear, along with the base plate and bubble 3". Being longer will also help it to be proportionate with the extra height. I will get it all to work and function as factory once done.
[Re: 6PKRTSE]
#2638722
03/30/19 08:54 AM
03/30/19 08:54 AM
Posts: 1,175 Woodbridge
Tommy The Chryco
Woodbridge
Hope this can assist you.
Fight the Good Fight- Elastomeric Bumpers and The Better "Shaker kits"
[Re: 71vert340]
#2639509
04/01/19 08:54 AM
04/01/19 08:54 AM
shaker340
Eastern Ontario
71340vert, it looks correct. It may be one of mine, but only three ever had the "RAD END" and 3462118 part number. The stamp was made by a fellow I thought from Colorado, Terry McCann got one and I got one as I supplied the original hose for the stamp to be modelled from. Anyway I had 20 made by Cooper rubber, only have a few left.
Mike
[Re: 6PKRTSE]
#2639511
04/01/19 08:56 AM
04/01/19 08:56 AM
shaker340
Eastern Ontario
6PKRTSE, thats great work you are doing to make a custom shaker set up for your tunnel ram.
Mike
[Re: shaker340]
#2639960
04/01/19 11:00 PM
04/01/19 11:00 PM
Posts: 673 Kennewick, Wa.
71vert340
Kennewick, Wa.
Mike Mike, I may have gotten it from Colorado. I can't remember ordering anything from up your way as it seems to cost a fortune because of shipping. It's good to know you have some. What would be cost with shipping to Washington state. 99336? PM me. Thanks. Terry
[Re: 71vert340]
#2640039
04/02/19 08:15 AM
04/02/19 08:15 AM
shaker340
Eastern Ontario
71vert340, I sold all of it to Tommy the Chryco yesterday. He will have them next week at the latest.
Mike
