Barry Grant ???????? #2636097
03/23/19 07:41 PM
03/23/19 07:41 PM
birdtracker Offline OP
will a BG400 work with E-85? thanks Birdtracker
Re: Barry Grant ???????? [Re: birdtracker] #2636111
03/23/19 08:11 PM
03/23/19 08:11 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I have been using mine with straight alcohol for years with zero issues. Knock on wood
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Barry Grant ???????? [Re: pittsburghracer] #2636134
03/23/19 09:10 PM
03/23/19 09:10 PM
Thanks John, just wanted the warm fuzzy feeling to run E-85 thru it. I just sat my motor in today and hope to fire it next weekend. Birdtracker
Re: Barry Grant ???????? [Re: birdtracker] #2636149
03/23/19 09:30 PM
03/23/19 09:30 PM
it will take me a few days. I am slow. Everything is different so I have to check and then recheck. I don't know even if my scoop will work due to height difference in the heads and intake. birdtracker
Re: Barry Grant ???????? [Re: birdtracker] #2636156
03/23/19 09:38 PM
03/23/19 09:38 PM
PA.
"Little"John
"Little"John
PA.
Looking good. Will you be able to get your valve covers off. It looks kinda close. Rebuild parts are readily available for those fuel pumps on racing junk and eBay. BG wouldn’t give you any parts as they wanted to fix them. Parts are cheap too
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Barry Grant ???????? [Re: pittsburghracer] #2636193
03/23/19 10:34 PM
03/23/19 10:34 PM
Optical illusion on the valve covers I believe! Birdtracker
Re: Barry Grant ???????? [Re: birdtracker] #2636205
03/23/19 11:06 PM
03/23/19 11:06 PM
Hermosillo, Sonora , México
I
Isaac Offline
Isaac  Offline
I
What's the compression ratio ?
Re: Barry Grant ???????? [Re: Isaac] #2636212
03/23/19 11:15 PM
03/23/19 11:15 PM
It's only 12-1 street car. Birdtracker
Re: Barry Grant ???????? [Re: birdtracker] #2636418
03/24/19 01:11 PM
03/24/19 01:11 PM
I've got a little over five years on my BG400 in my Cuda on local pump E85 up So far luck
My pump is mounted behind and a little below the front mounted fuel cell,I have the static pressure set at 5.5 lbs. with the car running at idle also shruggy
Re: Barry Grant ???????? [Re: Cab_Burge] #2636467
03/24/19 02:47 PM
03/24/19 02:47 PM
Cab: I have a Pro Systems dominator that uses a vaccum signal regulator. The tank is in the rear of the car and the pump is lower than the tank. Birdtracker
Re: Barry Grant ???????? [Re: birdtracker] #2636517
03/24/19 04:31 PM
03/24/19 04:31 PM
East Coast
A/MP Offline
A/MP  Offline
East Coast
The BG 400 will. Please take the time to read and follow the instructions! It is most important that the pump be below your fuel cell fuel connection.It must have full flow(gravity feed) prior to any use. 5/8" line feeds the inlet to the pump. Smaller than that will lead to premature pump failure. The BG filter elements will not work with any alcohol, pump gas 10-15% or e85. You'll need a prefilter that works with e85. There is an aftermarket BG filter but not sure if e85 will work.
Re: Barry Grant ???????? [Re: A/MP] #2636524
03/24/19 04:40 PM
03/24/19 04:40 PM
PA.
"Little"John
"Little"John
PA.
Learn how to make a proper return line into the tank. It explains this WELL in their instructions to prevent air in the fuel. Fuel should dump BELOW fuel level, not on top of it.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
