Re: Barry Grant ????????
[Re: birdtracker]
#2636111
03/23/19 08:11 PM
03/23/19 08:11 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
will a BG400 work with E-85? thanks Birdtracker I have been using mine with straight alcohol for years with zero issues. Knock on wood
[Re: birdtracker]
#2636156
03/23/19 09:38 PM
03/23/19 09:38 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Looking good. Will you be able to get your valve covers off. It looks kinda close. Rebuild parts are readily available for those fuel pumps on racing junk and eBay. BG wouldn’t give you any parts as they wanted to fix them. Parts are cheap too
[Re: birdtracker]
#2636418
03/24/19 01:11 PM
03/24/19 01:11 PM
Posts: 43,317 Bend,OR USA
Cab_Burge
I've got a little over five years on my BG400 in my Cuda on local pump E85 So far My pump is mounted behind and a little below the front mounted fuel cell,I have the static pressure set at 5.5 lbs. with the car running at idle also
[Re: A/MP]
#2636524
03/24/19 04:40 PM
03/24/19 04:40 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Learn how to make a proper return line into the tank. It explains this WELL in their instructions to prevent air in the fuel. Fuel should dump BELOW fuel level, not on top of it.
