NHRA Technical Department Makes Parity Adjustment to the SAM #2635280
03/21/19 04:04 PM
03/21/19 04:04 PM
PA.
pittsburghracer Offline OP
"Little"John
"Little"John
PA.
Based on SAMTech.edu NHRA Factory Stock Showdown performance numbers from the first race of the 2019 season, the NHRA Technical Department is increasing the supercharger top pulley size on the 2019 COPO 350 combination from 3.350 inches to 3.500 inches and the 2019 Cobra Jet 327 combination from 3.250 inches to 3.500 inches. This will decrease the 2019 COPO 350 combination supercharger overdrive from 147.5 percent to 136.6 percent overdrive or 10.9 percent. Additionally, this will decrease the 2019 Cobra Jet 327 combination supercharger overdrive from 146.2 percent to 128.6 percent or 17.6 percent. As a reminder, no other changes may be made to all approved superchargers, including, but not limited to: (upper or lower pulley sizes, gear ratios, cases, rotors, etc.). All other permitted combinations in the SAMTech.edu NHRA Factory Stock Showdown will remain unchanged. This rule change will go into effect immediately. NHRA reserves the right in the future to make additional rule changes to control performance and maintain parity in the category.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: NHRA Technical Department Makes Parity Adjustment to the SAM [Re: pittsburghracer] #2635287
03/21/19 04:25 PM
03/21/19 04:25 PM
New York
polyspheric Offline
polyspheric  Offline
New York
"maintain parity": insure a politically correct result, rather than one based on merit or achievement.
Apparently NHRA is now an agent of the Democratic Party.
Boffin Emeritus
Re: NHRA Technical Department Makes Parity Adjustment to the SAM [Re: polyspheric] #2635313
03/21/19 06:37 PM
03/21/19 06:37 PM
PA
Harry's Taxi 2 Offline
PA
I couldn't agree more.....penalize those that have done their homework, reward those that didn't..... it's becoming the American way!!!
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
Re: NHRA Technical Department Makes Parity Adjustment to the SAM [Re: polyspheric] #2635323
03/21/19 07:34 PM
03/21/19 07:34 PM
Washington
madscientist Offline
Washington
Yep. NHRA wants to control he outcome of races. That is certainly a democrat thing.
Re: NHRA Technical Department Makes Parity Adjustment to the SAM [Re: polyspheric] #2635324
03/21/19 07:48 PM
03/21/19 07:48 PM
"maintain parity": Democratic Party.
There is nothing Democratic about the Democrat party, NOTHING tsk whistling devil stirthepot whistling
Re: NHRA Technical Department Makes Parity Adjustment to the SAM [Re: Cab_Burge] #2635330
03/21/19 07:57 PM
03/21/19 07:57 PM
PA.
"Little"John
"Little"John
PA.
I guess this post won’t last long
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: NHRA Technical Department Makes Parity Adjustment to the SAM [Re: polyspheric] #2635334
03/21/19 08:09 PM
03/21/19 08:09 PM
Nevada
merpar Offline
merpar  Offline
Nevada
Couldn't agree more!
Re: NHRA Technical Department Makes Parity Adjustment to the SAM [Re: merpar] #2635336
03/21/19 08:10 PM
03/21/19 08:10 PM
Nevada
merpar Offline
merpar  Offline
Nevada
Meant to reply to Poly, I couldn't agree with you more.
Re: NHRA Technical Department Makes Parity Adjustment to the SAM [Re: merpar] #2635349
03/21/19 08:38 PM
03/21/19 08:38 PM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
+1 to everything before the post gets closed! up
Re: NHRA Technical Department Makes Parity Adjustment to the SAM [Re: gsmopar] #2635357
03/21/19 08:51 PM
03/21/19 08:51 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Nothing new. I recall the ever changing P/S weight breaks in the 70's when one combo was dominant over the others.
But this class is already a train wreck. Allow a super secret motor in the Challengers that you can only buy if you're in the "inner circle" from ONE shop, then add weight when that combo outruns all others. Then when the others out run that combo, you slow the blowers down???
Sounds like the NHRA circus has new clowns via this class.
Re: NHRA Technical Department Makes Parity Adjustment to the SAM [Re: pittsburghracer] #2635366
03/21/19 09:07 PM
03/21/19 09:07 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Who cares? Nobody is watching anyway.
Master, again and still
Re: NHRA Technical Department Makes Parity Adjustment to the SAM [Re: cudadoug] #2635370
03/21/19 09:14 PM
03/21/19 09:14 PM
COLUMBUS, OH
W
Whompin_Wedge Offline
W
COLUMBUS, OH
This thread has turned into a circus..
Super secret motor? What are you talking about? DSR built Pritchett and Pawuks motors, Mike Moran mostly built Joe Welch's, and BES built Turks.. All won races last year...
I agree Mopar did not do their homework over the winter.. The same could be said about Ford and Chevy last year I suppose.. NHRA is trying to keep it even.
Casey FJ
Re: NHRA Technical Department Makes Parity Adjustment to the SAM [Re: Whompin_Wedge] #2635372
03/21/19 09:20 PM
03/21/19 09:20 PM
PA.
"Little"John
"Little"John
PA.
I guess some guys don’t understand stock and super stock Racing.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: NHRA Technical Department Makes Parity Adjustment to the SAM [Re: pittsburghracer] #2635375
03/21/19 09:22 PM
03/21/19 09:22 PM
Washington
Washington
FSS is a heads up class. Stock and Super Stock for the most part, are not.
Re: NHRA Technical Department Makes Parity Adjustment to the SAM [Re: madscientist] #2635399
03/21/19 10:34 PM
03/21/19 10:34 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Geoff was very open about the fact that the improvements in the Dodges were from a redesigned air intake. He still has a standing offer to race any pre 2019 combination heads-up with one of his old motors in the car. No takers.
The CJ's and COPO's got fast with the stroke of a pen and guys cried their eyes out. Now NHRA is slowing them down a little and guys are still crying their eyes out. Amazing............
Re: NHRA Technical Department Makes Parity Adjustment to the SAM [Re: DaveRS23] #2635442
03/22/19 07:04 AM
03/22/19 07:04 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Ticket sales to the first races would say differently.
69 GTX 68 Road Runner
Re: NHRA Technical Department Makes Parity Adjustment to the SAM [Re: JERICOGTX] #2635478
03/22/19 09:22 AM
03/22/19 09:22 AM
North Central, Indiana
Roughbird72 Offline
Roughbird72  Offline
This kind of thing has been going on for a long time, who's surprised?
Someone comes out with a new setup/improvement and whining begins.
Turk made a comment on facebook that he had to work through changes with the Blackbird and now he'll have to work through the changes with the X-15 CJ ... it's racing.
I blame most of the Mopar camps problems on Dodge, why isn't there a 2019 Drag pack?
72 Plymouth Roadrunner 11.08@123.25
Re: NHRA Technical Department Makes Parity Adjustment to the SAM [Re: Roughbird72] #2635480
03/22/19 09:32 AM
03/22/19 09:32 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Just let everyone run the same blower at the same weight.
Doug
Re: NHRA Technical Department Makes Parity Adjustment to the SAM [Re: Whompin_Wedge] #2635497
03/22/19 10:10 AM
03/22/19 10:10 AM
New York
polyspheric Offline
polyspheric  Offline
New York
"Keeping it even": the opposite of racing
Boffin Emeritus
Re: NHRA Technical Department Makes Parity Adjustment to the SAM [Re: polyspheric] #2635508
03/22/19 10:29 AM
03/22/19 10:29 AM
PA.
"Little"John
"Little"John
PA.
Some of you guys are cement heads as far as open minded thinking. Last year the Mopars were hit with a weigh penalty to even the field. Over the winter ford and Chevy petitioned for changes to improve performance and the changes were approved. If Mopar were to ask for changes they probably would have been denied because they were already trying to slow them down. This class is called factory stock and as in all stock classes they hopefully will keep all and any manufacturers in check or we shall end up with Pro Stock II and I don’t think we want that
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
