Re: Shock settings, radial to bias
[Re: justinp61]
#2635044
03/21/19 01:05 AM
03/21/19 01:05 AM
Posts: 2,458 Sydney,Australia
tex013
Sydney,Australia
my understanding is they are almost opposite . IE : radial loose extension , tighter compression . Rag tyre tighter extension and less compression . You need to hit the radial harder and hold it there . BUT I only run radials , so what do I know My Vikings are 10 clicks clockwise compression and 5 clicks clockwise extension . They are also valved to suit radials . Rear . I have single adjust QA1 on font at full loose . Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: justinp61]
#2635047
03/21/19 02:16 AM
03/21/19 02:16 AM
Posts: 43,126 Bend,OR USA
Cab_Burge
On the front I would loosen up the extension and stiffen it up midway on the compression, rebound. On the rear I would split the extension halfway and same on the compression and go from there If we knew the weight, HP and body style we might be able to get you closer
[Re: Ian]
#2635211
03/21/19 12:59 PM
03/21/19 12:59 PM
Posts: 11,530 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Radials - aggressive suspension, separation, loose rebound, tight bump. Quite different from slicks. Hard to find a tune that will work for both with just a shock change, but, if I were trying, I would make the baseline aggressive and put a good shock on it be able to control it either way.
