chronic brake problems #2629761
03/06/19 08:51 PM
03/06/19 08:51 PM
MD
rich006 Offline OP
rich006  Offline OP
MD
Another question on my "new" 1989 D100. On the one-hour trip home from the previous owner's house, it was pretty clear there is a warped rotor or something (grinding sound and dragging feel during part of every wheel revolution). That was not the case when I test-drove it 10 days ago. Looking through the maintenance records from the previous owner, I see the following brake work.
Dec 2011 "pulls when braking" - replaced front pads/rotors
Jan 2012 left front caliper locked up - replaced caliper
Apr 2014 left front caliper smoking, right rear leak - replaced both front calipers and rear brake lines
Jun 2015 replaced both rear wheel cylinders
Sep 2015 cleaned/adjusted rear brakes
Mar 2016 replaced rear shoes and drums
Mar 2016 (two weeks later) replaced front brake hoses and right front caliper
Mar 2018 replaced rear shoes, hardware, and adjusting cable
This all occurred between 78K and 93K miles. Surely too much to be coincidence, right? What causes chronic brake problems?
Re: chronic brake problems [Re: rich006] #2629775
03/06/19 09:30 PM
03/06/19 09:30 PM
Freeport IL USA
poorboy Online content
poorboy  Online Content
Freeport IL USA
A truck that spends most of its time just sitting around. will have brake issues. If they don't get driven, lots of brake issues turn up because, not being used is really rough on calipers, rotors, wheel cylinders, shoes and drums.
It also sounds like the po only did the bare minimum to keep it rolling. Why would you do the front brakes without looking at the rear brakes at the same time, unless money was tight, or you didn't want to spend it? Gene
Re: chronic brake problems [Re: poorboy] #2629869
03/07/19 08:05 AM
03/07/19 08:05 AM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
replaced calibers three times in four years? I've been running D/W series trucks since 1985, have yet to replace a caliber yet.Might be the junk Chinese parts. And I've done the few parts at a time...family takes priority, so you can't always do a complete job at once.
1981 Dodge D150 360 auto
Re: chronic brake problems [Re: basketcase] #2630200
03/08/19 01:10 AM
03/08/19 01:10 AM
Freeport IL USA
Freeport IL USA
Looking down the list again, he probably solved the caliper problem when he changed what may have been the original front brake hose with the last caliper.
I did notice he only replaced the one front hose. Wonder what the other front hose looks like, and what the rear hose looks like..... Gene
Re: chronic brake problems [Re: poorboy] #2630217
03/08/19 06:57 AM
03/08/19 06:57 AM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Yep.
I agree,
Should replace existing old hoses.
I have mechanical Aptitude.
I can screw up anything.
Re: chronic brake problems [Re: bboogieart] #2632402
03/13/19 07:56 PM
03/13/19 07:56 PM
MD
rich006 Offline OP
rich006  Offline OP
MD
Turns out all the brake components are fine, but the parking brake cable was binding on a frame bracket. Easy fix--but probably a gripe that would never occur on a frequently driven truck.
Re: chronic brake problems [Re: rich006] #2632774
03/14/19 07:42 PM
03/14/19 07:42 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Wow,
Wouldn't have guessed.
I bet it's an automatic.
Rarely is the E brake ever used as long as the park pawl holds up.
This is why we shouldn't just throw parts at problems.
Glad you got it sussed out. up
Re: chronic brake problems [Re: bboogieart] #2634288
03/19/19 06:44 AM
03/19/19 06:44 AM
Michigan Detroit area
Doc Schwarz Offline
Doc Schwarz  Offline
My problem with my 1977 ramcharger was the plastic pistons.
Every six months had to rebuild the calipers.
Finally put a steel pistons in them and all was solved.
Re: chronic brake problems [Re: poorboy] #2634432
03/19/19 01:54 PM
03/19/19 01:54 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
True about the rear hose. Could be collapsing too.
Facts are stubborn things.
Re: chronic brake problems [Re: rich006] #2634433
03/19/19 01:55 PM
03/19/19 01:55 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Glad you found the issue!! up
