Axle straps #2633965
03/18/19 09:47 AM
03/18/19 09:47 AM
STL
cdstl Offline OP
cdstl  Offline OP
STL
I'm looking for a good set of axle tie down straps. I plan on loading a 2nd Gen CTD onto a trailer to bring home at some point. I've decided that a 24" axle strap is a minimum, and then a ratchet strap to hook onto those.
Rhino USA seems to have a good product.
Mac's seem to be pretty good too.
I'm open to suggestions.
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: Axle straps [Re: cdstl] #2634036
03/18/19 12:51 PM
03/18/19 12:51 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
We got ours from Summit.IIRC they were their brand along with their tie downs.That was about 15 years ago.Still like new.Rocky
Chrysler Firepower
Re: Axle straps [Re: therocks] #2634042
03/18/19 01:14 PM
03/18/19 01:14 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Mac's is about as good as you can get.
But I've bought others at car shows & swap meets that have been plenty adequate for many years now.
I've avoided those yellow ones from hardware/home stores for automotive use ever since having one fray in half almost 30 years ago.
Re: Axle straps [Re: topside] #2634169
03/18/19 07:45 PM
03/18/19 07:45 PM
Round Lake Beach, Illinoisy
Rhinodart Online penguin-006
Rhinotruck
Rhinodart  Online Penguin-006
Rhinotruck
I always use Macs, wouldn't trust anything thats called Rhino... biggrin
JB Rhinehart, Realist
A-Body's RULE!
Re: Axle straps [Re: cdstl] #2634215
03/18/19 09:33 PM
03/18/19 09:33 PM
tucson az
frank Offline
frank  Offline
tucson az
I use Rhino. Good product and last long time.
Re: Axle straps [Re: frank] #2634687
03/20/19 08:03 AM
03/20/19 08:03 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
A strap on the rear axle will often slide to the side. Outside it is usually towards the shock absorber body, not a great situation. Inside is towards the differential, which is not an ideal place to pull a housing backwards in the middle. I'm sure it's been done 1000' s times before, including by me but for example an 8 1/4 with pressed in axle tubes, was never mean to be pulled by the middle.
What I do not recommend is attaching to anything like the frame. As the car/truck cycles the suspension. The straps will be loose on suspension compression and it will violently hit the straps as it extends.
The best method is holding the tires.
