Axle straps
#2633965
03/18/19 09:47 AM
03/18/19 09:47 AM
Posts: 1,487 STL
cdstl
STL
I'm looking for a good set of axle tie down straps. I plan on loading a 2nd Gen CTD onto a trailer to bring home at some point. I've decided that a 24" axle strap is a minimum, and then a ratchet strap to hook onto those.
Rhino USA seems to have a good product.
Mac's seem to be pretty good too.
I'm open to suggestions.
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: Axle straps
[Re: cdstl]
#2634036
03/18/19 12:51 PM
03/18/19 12:51 PM
Posts: 21,079 Niles , Ohio
therocks
Niles , Ohio
We got ours from Summit.IIRC they were their brand along with their tie downs.That was about 15 years ago.Still like new.Rocky
Chrysler Firepower
Re: Axle straps
[Re: topside]
#2634169
03/18/19 07:45 PM
03/18/19 07:45 PM
Posts: 43,595 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
I always use Macs, wouldn't trust anything thats called Rhino...
JB Rhinehart, Realist
A-Body's RULE!
Re: Axle straps
[Re: frank]
#2634687
03/20/19 08:03 AM
03/20/19 08:03 AM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
A strap on the rear axle will often slide to the side. Outside it is usually towards the shock absorber body, not a great situation. Inside is towards the differential, which is not an ideal place to pull a housing backwards in the middle. I'm sure it's been done 1000' s times before, including by me but for example an 8 1/4 with pressed in axle tubes, was never mean to be pulled by the middle.
What I do not recommend is attaching to anything like the frame. As the car/truck cycles the suspension. The straps will be loose on suspension compression and it will violently hit the straps as it extends.
The best method is holding the tires.
