I prefer to cut the carton off of the foam shell , then peel that away to reveal the product. I hate to veer off course , but I have to ask what kind of shank you sliced the carton open with ? I am a long time collector of sharp and pointy things. It had a Benchmade look and feel , but I never got a good look at it. And I will be judging you harshly if your reply has either " Wal-Mart " or " Chinese " in any part of the description. lol
Re: ATL Racing Fuel Cell unboxing
[Re: tubtar]
#2633543 03/17/1907:20 AM03/17/1907:20 AM
It clearly has the Benchmade Butterfly on it, my guess is the Infidel
Not exactly what the 6 black plastic tabs are for? They don't locate anything or hold the fill plate down any further? Both our fuel cells have them though. I'll ask ATL tomorrow when I call them for the aluminum fill plate.
Curious, what purpose are the 6? black tabs spaced around filler plate for?
Just talked to Mr. Ron Ross at ATL and he was cool enough to send me the correct aluminum fill plate for the MAX option. He said he's never seen that happen before haha! Below is the `Cuda's red aluminum plate which weighs 2 pounds less than the blue steel plate.
As for the 6 black plastic tabs, they are there to help grab onto the aluminum box so it does not move around. The fill plate is mostly bolted down onto the hard rubber bladder inside. If it were not for the 6 black tabs, one could just push down on the fill plate and the hard bladder would shift inside the aluminum box.
The tabs are a way for the fill plate to "grip" onto the aluminum box better. If the tabs were not there then the fill plate and bladder would be able to shift or be pushed down inside the aluminum box.
As for the fuel pump it is a Walbro GSS340 style EFI pump inside a "black box" with 3 trap doors to help centralize the fuel.
The foam is pretty sturdy and secure as the black box is wedged in tight and nowhere to go. That being said the foam in the `Cuda is getting to be 5 years old and requires replacement very soon.
Going to make a video on how to replace the fuel cell foam after we get back from Spring Fling Speed Festival April 11th at Willow Springs International Raceway. Hopefully I don't light myself on fire from all the gasoline fumes haha!
