Re: 572 Vacum Pump
[Re: Raffaplymouth60]
#2625769
02/25/19 06:55 AM
02/25/19 06:55 AM
Posts: 2,937 A shed in England
Tig
A shed in England
Where is your Vac regulator mounted?
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
Re: 572 Vacum Pump
#2625850
02/25/19 02:12 PM
02/25/19 02:12 PM
Posts: 19,384 Las Vegas
Al_Alguire
Las Vegas
You likely don't NEED a regulator as it will never pull enough to hurt anything. Just my .02
Re: 572 Vacum Pump
#2625942
02/25/19 05:27 PM
02/25/19 05:27 PM
Posts: 4,584 Motor City
6PKRTSE
Motor City
I first mounted mine in the Indy valley tray. It filled my catch can on the first dyno pull even with a Morose 22635 positive seal vented fitting. I moved it to the valve cover and after 17 pulls it barely had anything in the catch can.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
Re: 572 Vacum Pump
[Re: Al_Alguire]
#2625949
02/25/19 05:44 PM
02/25/19 05:44 PM
Tig
A shed in England
You likely don't NEED a regulator as it will never pull enough to hurt anything. Just my .02 I heard that anything over 12in/Hg was too much on a wet sump. I had to adjust mine to get under that using a 4 vane Moroso BTW. I've seen folk mount the reg on the opposite rocker cover to the take off, this way there is an air flow through the engine and you will pull oil through.
Re: 572 Vacum Pump
[Re: Tig]
#2626125
02/26/19 12:02 AM
02/26/19 12:02 AM
Posts: 43,303 Bend,OR USA
Cab_Burge
[quote=Al_Alguire] I've seen folk mount the reg on the opposite rocker cover to the take off, this way there is an air flow through the engine and you will pull oil through. This is exactly what GZ says to NOT DO, don't suck outside dirty air across the motor I've heard and know racers that shoot for 17.0 inches at the starting line with a regular wet sump oil system ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) I get barely 5.0 inches with my current GZ pump in neutral revved up ![whiney whiney](/ubbthreads/images/graemlins/custom/whiney.gif) The next motor will have the Moroso 4 vane pump on it and I'll do every thing I can to seal it up so it holds a vacuum ![luck luck](/ubbthreads/images/graemlins/custom/luck.gif)
Re: 572 Vacum Pump
[Re: Cab_Burge]
#2626244
02/26/19 11:30 AM
02/26/19 11:30 AM
Posts: 13,400 Marion, South Carolina [><]
an8sec70cuda
I started off w/ an Aerospace vacuum pump kit which is a total piece of crap. Had 2 pumps fail and the mandrel is junk too. Never pulled more than about 6-7" w/ the regulator closed. The regulator is mounted on the intake side of the pump itself.
I switched to a Moroso 4 vane pump and CV products mandrel drive setup and couldn't be happier. It pulls 10" at half throttle where it is set right now...honestly not sure what it pulls at WOT.
Mine pulls from the driver's side valve cover w/ no baffle at all. No issue pulling too much oil. I drain it after I get home from the track.
Re: 572 Vacum Pump
[Re: an8sec70cuda]
#2626402
02/26/19 05:37 PM
02/26/19 05:37 PM
Posts: 195 Italy
Raffaplymouth60
Italy
Mine pulls from the driver's side valve cover w/ no baffle at all. No issue pulling too much oil. I drain it after I get home from the track. OMG i don't have this valve , i see in your pictures on my vacuum pump !
1970 Cuda 496 street driven 9.22@150 1971 Demon 572 7.82@176 1957 Desoto Adventurer Convertible 345 Hemi 1958 Plymouth Fury Christine 2008 Dodge Ram 1500 Hemi 1970 Dodge ChallengerRT 6pack 4 speed 1 of 135 1968 Dodge Charger RT 4 speed
Re: 572 Vacum Pump
#2626404
02/26/19 05:53 PM
02/26/19 05:53 PM
an8sec70cuda
Do you have a gauge on the car so you can see how much vacuum it's pulling? Put the line on the valve cover first. You may not need a regulator at all depending on how much it pulls.
Re: 572 Vacum Pump
#2626409
02/26/19 06:03 PM
02/26/19 06:03 PM
6PKRTSE
Motor City
I have the same reg as pictured on my Hemi also. I only picked up about 8 hp with the pump and mine also make 10in of vac. But that was mainly due to that I run an old school std tension 1/16, 1/16, 3/16 ring pack due to being a street car. Others results will vary from engine to engine.
Re: 572 Vacum Pump
[Re: 6PKRTSE]
#2626413
02/26/19 06:11 PM
02/26/19 06:11 PM
Posts: 195 Italy
Raffaplymouth60
Italy
I first mounted mine in the Indy valley tray. It filled my catch can on the first dyno pull even with a Morose 22635 positive seal vented fitting. I moved it to the valve cover and after 17 pulls it barely had anything in the catch can. Nice !
Re: 572 Vacum Pump
[Re: an8sec70cuda]
#2626414
02/26/19 06:12 PM
02/26/19 06:12 PM
Posts: 195 Italy
Raffaplymouth60
Italy
Do you have a gauge on the car so you can see how much vacuum it's pulling? Put the line on the valve cover first. You may not need a regulator at all depending on how much it pulls. bought now on Summitracing !
Re: 572 Vacum Pump
[Re: Al_Alguire]
#2626417
02/26/19 06:16 PM
02/26/19 06:16 PM
Posts: 195 Italy
Raffaplymouth60
Italy
If hood clearance is an issue you can put it on the inside portion of the valve cover between rocker arms possibly. Not sure what head and rocker set up you have but its worth looking at. Along with the Moroso baffle you should be way better. UNLESS you have an external leak. nice information
Re: 572 Vacum Pump
#2627563
03/01/19 03:16 PM
03/01/19 03:16 PM
Al_Alguire
Las Vegas
The engine in the Cuda went 404 passes at its last freshen up. It pulls 16-17" of vacuum and there has NEWVER been an issue with the pins period. That was freshen up number 2 on those pins and pistons, they had a total of 782 laps on them since new when I sold it. Still at 16-17" of vacuum, never an issue
In the heads up car we pull 20-21" each pass. Engine comes out every year. Never an issue with pins or pistons. Both ran 4 vane enhanced Moroso pumps and both are wet sumps. Just stating my EXPERIENCE not speculation.
Re: 572 Vacum Pump
[Re: Al_Alguire]
#2627620
03/01/19 06:13 PM
03/01/19 06:13 PM
Tig
A shed in England
In the heads up car we pull 20-21" each pass. Engine comes out every year. Never an issue with pins or pistons. Both ran 4 vane enhanced Moroso pumps and both are wet sumps. Just stating my EXPERIENCE not speculation. Good to know ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) Every days a school day ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif)
Re: 572 Vacum Pump
#2628000
03/02/19 06:34 PM
03/02/19 06:34 PM
Posts: 195 Italy
Raffaplymouth60
Italy
hello ! news is : installed relief valve and i have relocated the puller in the left cover i would know how quantity of oil can suck in 10 second at 7000 rpm ? i have installed also the vacuum gauge .. and at max RPM i read 10 of vacuum
