727 Build Cost #2630331
03/08/19 11:55 AM
03/08/19 11:55 AM
Metro Detroit
1970RT Offline OP
1970RT  Offline OP
Metro Detroit
I'm having a big block stroker motor built that I'm guesstimating will be about 600 HP. I have a currently stock 727 trans. from a 440 HP motor that I will be using with it that I need to have gone through and upgraded to handle the increased HP. I've never had a trans. done like this before so I have no idea what to expect price-wise. I haven't got any quotes yet but if it's like everything else, I expect there to be a range in the prices I am quoted. So what I would like to know is, what do you think a fair price would be to have this work done?
Re: 727 Build Cost [Re: 1970RT] #2630349
03/08/19 12:41 PM
03/08/19 12:41 PM
Las Vegas, NV
Tom_440 Offline
Tom_440  Offline
Las Vegas, NV
If you have a skilled local trans shop, I would consider comparing costs with a known 727 builder like Cope...
http://coperacingtranscom.ipage.com/?product_cat=727
Re: 727 Build Cost [Re: 1970RT] #2630384
03/08/19 01:41 PM
03/08/19 01:41 PM
Mequon, WI
gzig5 Offline
gzig5  Offline
Mequon, WI
Last fall I paid $1200 for the rebuild of my 727. That included a bunch of internal parts because it was in pretty bad shape. Came with a new 2500 rpm converter and I told him it needs to hold up to 500+ lb-ft of torque (future engine) so it got a bolt in sprag. I think that was pretty fair pricing. I did the R&R of the transmission and dropped it off to save the ~$300 labor for them to do it.
Re: 727 Build Cost [Re: gzig5] #2630545
03/08/19 08:50 PM
03/08/19 08:50 PM
So Cal, USA
Fab64 Offline
Fab64  Offline
So Cal, USA
I just had my (c. 1965 model) 727 done 6 months ago, and included a rebuild kit, later-model pump & direct drum, a shift kit, accumulator piston, and front planet 4 pinion - total bill was $875 (parts $575, labor $300, 12-month, 12,000 mile warranty), and that was without a torque converter. I bought a B&M separately, for $370.
Re: 727 Build Cost [Re: 1970RT] #2630584
03/08/19 10:07 PM
03/08/19 10:07 PM
SoMd, USA
135sohc Offline
135sohc  Offline
SoMd, USA
The price of a transmission build can vary widely depending upon how its quoted. Some builders will follow a more conservative approach and reuse certain components that others following a more CYA approach would scrap and replace regardless. The low bid may be based upon all normal non consumables are good for reuse and then they start nickel and diming you as they find parts need to be replaced, vs the high bid where all the bushings, pump gears, new front planet ect are all automatically replaced. A detailed enough quote saying what exactly will be done/parts replaced would be the best way to know what your $ is buying.
Re: 727 Build Cost [Re: 1970RT] #2630586
03/08/19 10:14 PM
03/08/19 10:14 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
IMHO I would consider John Cope/CRT for your needs, I've sent quite a few customers his way, and all have been more than pleased with the product/service and pricing over the years
Re: 727 Build Cost [Re: DAYCLONA] #2630593
03/08/19 10:32 PM
03/08/19 10:32 PM
Martinsville, IN
cdwmotorsports Offline
Martinsville, IN
I would have Joe at TranzAct build your transmission. I will also say that he top three MoPar trans. builders are in Indiana. TranzAct, A&A and Cope. Not listed in any particular order.
eBay-cdwmotorsports
Re: 727 Build Cost [Re: cdwmotorsports] #2630611
03/08/19 11:25 PM
03/08/19 11:25 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Assuming all the hard parts are serviceable, Mancini used to sell a race rebuild kit with the good clutches and steels, all the seals etc shift kit and a deep pan for about $300.
I dropped my core off with that kit to my trans guy and he charged me $300 cash to build it. That was a while ago so I'd expect it to be a little more now but should still be no more than $800ish.
Shouldn't take more than 3 or 4 hours tops to clean and build it.
Kevin
Re: 727 Build Cost [Re: Twostick] #2630629
03/09/19 01:09 AM
03/09/19 01:09 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
your location may have some effect on price .
where are you located ?
what will the trany be used for street , race , both ?
compression and cam ?
auto or manual valve body ?
shift pattern forward , reverse ?
converter stall speed ?
Re: 727 Build Cost [Re: 1970RT] #2630792
03/09/19 02:53 PM
03/09/19 02:53 PM
CA
crackedback Offline
crackedback  Offline
CA
They aren't hard to rebuild and the stock stuff can handle a decent power level.
Northern auto for a rebuild kit, wit or some others for bands, get a bolt in sprag if you want it and the TF book.
There is a series on youtube from a shop in Australia that does a performancce rebuild on a 727. Good resource.
https://www.youtube.com/watch?v=xzJhCBZ1wMY
Lots of BS black magic regarding building mopar transmissions. They are probably the easiest to get done. Save money on the trans rebuild and spend that money on a great converter that will REALLY make a difference in how the car runs.
Re: 727 Build Cost [Re: crackedback] #2631137
03/10/19 04:24 PM
03/10/19 04:24 PM
Keizer, Oregon U.S.A.
E
elmor353 Offline
elmor353  Offline
E
I bought a DVD from www.technicalvideos.com and it walks you through a teardown, parts inspection and assembly. It's a very straightforward video and got me through the rebuild of my 727. Only cost me $20 and saved me a bunch of money in the process.
Re: 727 Build Cost [Re: DAYCLONA] #2631147
03/10/19 04:53 PM
03/10/19 04:53 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
Agreed, John built one for a friend of mine and I have to say his customer service was beyond approach. Even well after the day of sale .
Costs were not much more than I planned for a stock build.
