Window Tinting Removal
#2629109
03/05/19 12:57 PM
03/05/19 12:57 PM
Posts: 16,145 Mesa, Arizona
dart4forte
Mesa, Arizona
Anyone here have any experience removing window tinting? Working on the back window on a PU and man that stuff is tough. Razor blade, heat gun and WD doesn’t seem to do a lot.
Abe Lincoln
Re: Window Tinting Removal
[Re: buildanother]
#2629201
03/05/19 03:17 PM
03/05/19 03:17 PM
dart4forte
Mesa, Arizona
This film is on there. WD seems to loosen it a bit but not much
Abe Lincoln
[Re: dart4forte]
#2629236
03/05/19 04:30 PM
03/05/19 04:30 PM
Posts: 16,477 On the run…
BloFish
On the run…
I used a razor blade, nail polish remover and a lot of patience!
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: 5thAve]
#2629458
03/06/19 12:22 AM
03/06/19 12:22 AM
dart4forte
Mesa, Arizona
Got it off. Lots of razor blades and WD40.
Abe Lincoln
[Re: dart4forte]
#2629471
03/06/19 01:06 AM
03/06/19 01:06 AM
Posts: 954 garnett kansas
rhad
garnett kansas
soak it in sudsy ammonia,grocery store or hdwe store then a razor blade
my ladder of success is missing some rungs
[Re: gzig5]
#2629930
03/07/19 11:40 AM
03/07/19 11:40 AM
dart4forte
Mesa, Arizona
Like I said, got it done. Cab smells from a combination of WD and Windex.
Abe Lincoln
[Re: dart4forte]
#2631310
03/11/19 02:33 AM
03/11/19 02:33 AM
Posts: 5,789 Hamilton, Ontario Canada
Magnum
I've done it a few times and ease of removal depends on the age and quality of the tint.
If it doesn't tear, I've removed the whole sheet in about 2 minutes. When it's really cooked on and the tint is brittle, I've spend hours with many breaks in between attempts.
The glue removal is another big time consumption. Brake cleaner, WD40, GooGone, solvent. All need to be tried to see what works best for you.
[Re: Magnum]
#2631381
03/11/19 10:52 AM
03/11/19 10:52 AM
dart4forte
Mesa, Arizona
The glue removal is another big time consumption. Brake cleaner, WD40, GooGone, solvent. All need to be tried to see what works best for you. I found the glue removal to be the easy part. I used #0000 steel wool and WD. Came right off.
Abe Lincoln
