Blasphemi leaks #2628210
03/03/19 11:53 AM
03/03/19 11:53 AM
West Palm Beach, Florida
Craig J Offline OP
Craig J  Offline OP
I have a fake 69 Super Bee. I bought it with a stock 318+904+8 3/4 with the intention to change it to reproduction Gen 2 hemi+A518+S60.
Are the Blasphemi hemi problems common for aftermarket block & head hemi's ?
In particular, why does the push rod almost touch the fire ring?
https://youtu.be/vjriSwbDaEQ?t=1638
Re: Blasphemi leaks [Re: Craig J] #2628237
03/03/19 01:32 PM
03/03/19 01:32 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Only if you put 20+ pounds of boost to the motor making 1200hp. The push rods were hitting the head gasket and they reluctantly had to enlarge them.
You will be fine running a street hemi. up
Re: Blasphemi leaks [Re: moparpollack] #2628388
03/03/19 07:32 PM
03/03/19 07:32 PM
my own world
theraif Offline
theraif  Offline
my own world
iagree plus pushing that car into the 8 sec zone
Re: Blasphemi leaks [Re: Craig J] #2628554
03/04/19 02:47 AM
03/04/19 02:47 AM
I ran into a similar head gasket problem on a KB street hemi aluminum block, with standard head gaskets, not custom made head gaskets for that block, water would leak between the gasket and heads and or block into the ring around the sleeves and then run down the exhaust pushrod hole shock runaway
The cure was to use medical 00 stuture thread for sewing up people with Gasket Cinch as the adhesive to hold the stuture in place around every water hole on the block. I made a small circle around every water passage after being told about this trick by the head machinest at KB
This was for a all aluminum blown pump gas street Hemi motor that I had SCE gasket company make the custom made copper head gaskets that KB provide the design for up
Hemiroid motors are known to me by that name for problems like that runaway whiney shruggy
Anytime I see screw in welsh plugs in the lifter valley I know it is after market block and to pay special attentions to details like head gasket application and other small issues related to them dang hemiroid motors while assembling them shruggy
Re: Blasphemi leaks [Re: Craig J] #2628594
03/04/19 10:36 AM
03/04/19 10:36 AM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
I had a similar experience with my World aluminum block with water in the oil. What I found out was the Aluminum World block with the three water holes on the lower part of the deck are are closed off using the gasket in the picture.That gasket is for the iron block. I got this tip from Rich Nedbal . He gave me the correct part number for the Cometic gaskets made for this block with the three large oval holes open. The aluminum block does not have the smaller holes at the lower part of the deck like the iron block has ? Also the correct gasket fits the upper water passages better.
I sealed the passages with a thin smear of Hylomar on the gaskets.
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Blasphemi leaks [Re: Hemi Allstate] #2628938
03/05/19 12:26 AM
03/05/19 12:26 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
I have one head that does this on a Hemi Products POS block, drops of water ooze out and run down in the valley. I like the idea of putting thread around the water passages. This reminds me, that all small opposed airplane engine cases are done this way with silk thread.
Re: Blasphemi leaks [Re: Craig J] #2629000
03/05/19 03:22 AM
03/05/19 03:22 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Hylomar and silk thread...
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Blasphemi leaks [Re: astjp2] #2629267
03/05/19 04:22 PM
03/05/19 04:22 PM
I learned about Hylomar from owning my Comanche, good stuff !
Re: Blasphemi leaks [Re: Craig J] #2630289
03/08/19 10:40 AM
03/08/19 10:40 AM
Martinsville, IN
cdwmotorsports Offline
Martinsville, IN
My son and I love Finnegan's channel and Roadkill both. Mike sure has had a heck of a time with "that" Hemi. This is at least the 2nd if not the 3rd Hemi he's had in it. Runs great, and his solution kept it running well enough to beat John Chase out of his beard.
eBay-cdwmotorsports
